Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 189521 times)
Offline BLAC
  • An espresso is a
Re: 1974 CB550. Monoshock. Engine Build. "BLAC"
« Reply #500 on: January 30, 2017, 03:44:31 PM »
Sorry, got it fixed (image)
Thanks for the kind words!
« Last Edit: January 30, 2017, 03:58:42 PM by BLAC »
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline 540nova
« Reply #501 on: January 30, 2017, 05:12:45 PM »
Just saw the first picture, which wasn't viewing before. Again, great looking welds!
Offline Restoration Fan
  • My wife will never call me
« Reply #502 on: January 30, 2017, 06:30:12 PM »
Yeah, Bryan, I was going to comment earlier that your welding talent far exceeds mine.  Really enjoying this build a lot.  You have some serious talent and a very good attention to details and it will show in the final product.  This is going to be one sexy bike!
Offline BLAC
  • An espresso is a
« Reply #503 on: January 30, 2017, 08:05:12 PM »
Thank you! I welded quite a bit in HS (12 years ago) but just got back into it in the last couple months.. I probably have about 2 hours of practice on this machine.  The hard part for me is getting the machine set correctly, I run beads on similar stock before getting on my bike getting that dialed in.
The other part is getting all the pieces to fit right so I don't have to glob up the welds to fill gaps.  And that just comes from me being very anal and detailed (i.e. Slow moving) on the metal fabbing.
I do appreciate the kind words and support, I have never done a build this deep before so I'm learning as I go!
Offline BLAC
  • An espresso is a
« Reply #504 on: January 30, 2017, 08:55:35 PM »
I think it is safe to say the subframe and monoshock-swingarm hoop is all square and even...  8)
« Last Edit: January 30, 2017, 09:01:53 PM by BLAC »
Offline BLAC
  • An espresso is a
« Reply #505 on: January 30, 2017, 11:13:54 PM »
Does anyone have a list of the oil seal part numbers? I want to buy OEM but don't see a kit available and it looks like im going to have to piece meal it together.  Im away on business for a couple days so I am away from my parts manual but here is what I found online (but am not entirely sure it is accurate)
If anyone knows of a thread where these part numbers are all in the same place, please point me to it!
91259-VM0-000 - 10X16X4.5  Clutch lever
91202-426-003 - 12X25X4.5  Gearshift Drum
91202-KFL-841 - 13.8X24X5  Gearshift Spindle
91204-286-003 - 18X29X7  Right Crankcase Cover
91201-300-003 - 30X42X8  Crankshaft
91201-323-005 - 30X45X8  Crankshaft
91205-283-015 - 33X57X7  Countershaft
91207-374-000 - 34X8 FLAT SEAL Main-shaft
91256-096-651 - 4.8X14.5X4  Tach seal
UPDATE: I just did tons or research and ordered 41 OEM gaskets/seals for my bike... There are a couple of those bastards that are NLA and people are asking an arm an a leg on ebay for them...  >:(
« Last Edit: January 31, 2017, 12:36:13 AM by BLAC »
Offline Godffery
  • Godffery's Garage
« Reply #506 on: January 31, 2017, 03:38:37 AM »
 I have done a few of these Conversions, so I can say with experience, You are doing a fine job!  Never worry about how ling it takes to get it right, worry about how long it will take to Fix it if you try to rush threw it! =)
 Here are a couple pix from ones I've converted:
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Cafe+Overkill/DSC+285.JPG.html?g2_imageViewsIndex=1
« Last Edit: February 01, 2017, 02:50:18 PM by Godffery »
Offline BLAC
  • An espresso is a
« Reply #507 on: February 01, 2017, 11:01:07 AM »
beautiful work, I have spend time looking at some of your builds  8)
« Reply #508 on: February 01, 2017, 11:15:18 AM »
There should be oilseal kits available with all the seals. .check with suppliers or ebay.
Offline BLAC
  • An espresso is a
« Reply #509 on: February 01, 2017, 11:17:58 AM »
I couldnt find any that used (or were clear about using) OEM parts, it was just "fits cb550" so I just compiled a list of part numbers and bought OEM piece by piece via partzilla
I also got a NOS gasket kit (kit B) on the way
Offline Godffery
  • Godffery's Garage
« Reply #510 on: February 01, 2017, 02:54:27 PM »
There is a guy out of Canada selling Seal kits on FeeBay. I'm not sure if they are OEM, but I have used his kits at least 3 times in the past with no issues.
Offline BLAC
  • An espresso is a
« Reply #511 on: February 01, 2017, 09:25:55 PM »
I think I found the guy you are talking about.  I couldn't tell if they were factory or not either...
I am relatively new to all of this so I don't know what brands to trust or to avoid (with respect to gaskets and the like).
I think I have most everything on the way... I think it was over more than 40 pieces in total.
Offline Godffery
  • Godffery's Garage
« Reply #512 on: February 01, 2017, 10:37:44 PM »
 I have noticed that the aftermarket Head Gaskets tend to fail.
Offline BLAC
  • An espresso is a
« Reply #513 on: February 02, 2017, 11:02:00 AM »
Make sure you get in touch with member, Elan, and pick up his Oil Pump rebuild kit. He has the NLA o-rings and internals (not rotor) that you will need.
Thanks for the info! I reached out to him and he directed me to his kit on ebay.
Here is the link for other: http://www.ebay.com/itm/162179190728
Offline BLAC
  • An espresso is a
« Reply #514 on: February 02, 2017, 05:17:38 PM »
Nils just sent me some engine porn.  Viewer discretion is advised..
« Reply #515 on: February 02, 2017, 05:30:36 PM »
Hot gif DAMN!!  Your engine crankcase wasn't too bad at all to start with, but now it's brand spanking new looking!
Offline BLAC
  • An espresso is a
« Reply #516 on: February 02, 2017, 05:34:45 PM »
I'm still waiting for someone to say "Thanks, Cal!" for goading you into it...  >:(
th.... thank..... thanks.... Cal...  ::)
You were right, I was wrong! I just hope you are ready to field some questions about reassembly  :P
« Reply #517 on: February 02, 2017, 05:35:56 PM »
That's hideous!  I'm sure you would much rather Nils send those ugly, clean cases to me and I'll send you the ones I have that are much more, umm....."real looking".  ::)
Offline BLAC
  • An espresso is a
« Reply #518 on: February 02, 2017, 05:38:03 PM »
ya what kind of bike doesn't have that authentic dirt on it?! Ill trade you straight across =P
These look so clean it looks like a render in some pics haha
Offline BLAC
  • An espresso is a
« Reply #519 on: February 02, 2017, 05:39:02 PM »
Absolutely! My most insightful answer will be, "Ask someone who knows better than I"  ;D ;D ;D
fine, I'll just ask Jwilde  ;D
« Reply #520 on: February 02, 2017, 05:39:47 PM »
They really are gorgeous.  You have to be getting excited to put this thing back together.
This is going to be one really sweet bike when it's rideable.  Looking forward to seeing it street-ready.
Offline BLAC
  • An espresso is a
« Reply #521 on: February 02, 2017, 05:44:06 PM »
thanks, and yes, I cant wait to get it down to Racetech so they can start making my monoshock!  Then I just have to choose a color scheme, tank fab work, assemble the entire engine..  :-[ I guess I'm still a long way away haha
I did get plates cut out for the monoshock mounting to the swing arm and up under the tank  8)
Offline BLAC
  • An espresso is a
« Reply #522 on: February 02, 2017, 05:45:03 PM »
Them's fightin' words!!!!  >:(
 ;D jk I do appreciate all of your insight on my build.  You and the people like you on this forum are a huge asset to the rookies like me.
Offline SF
  • I burn gas very well
« Reply #523 on: February 02, 2017, 05:47:02 PM »
Looks so good man. I'll be definitely getting mine done. Thanks for posting.
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #524 on: February 02, 2017, 05:48:52 PM »
Thanks Cal!
I have a motorcycle problem.
