Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 190459 times)
Offline BLAC
  • An espresso is a
Re: 1974 CB550. Monoshock. Engine Build. "BLAC"
« Reply #725 on: March 01, 2017, 01:02:07 PM »
Check out Etak-Nivek Blac when your ready to upgrade. I just purchased front forks from them. Classic,Ceriani looks with modern internals rebound dampening and preload adjustment. Kevin is an awesome dude.
That looks awesome! I will be sure to keep track of that. Let me know how they work out for you!
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline Camrector
« Reply #726 on: March 01, 2017, 01:21:04 PM »
Will do brother!
I found NOS 38mm Ceriani lowers and Kevin at E-N used his tubes and internals. His reproductions though are awesome.
Offline SF
  • I burn gas very well
« Reply #727 on: March 01, 2017, 04:02:06 PM »
Godfrey garage for the phenolic piston
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Godffery
  • Godffery's Garage
« Reply #728 on: March 01, 2017, 04:38:46 PM »
 Godffery’s Garage http://tinyurl.com/yfrw4fc
Burlington WI. 53105
 Jstephens7@wi.rr.com   262-210-9269
« Reply #729 on: March 01, 2017, 04:57:31 PM »
The source!
Offline BLAC
  • An espresso is a
« Reply #730 on: March 01, 2017, 07:50:16 PM »
Ordered  :D
I also got the DOW high vacuum grease, which I am guessing is fine to use around this piston also?
Offline BLAC
  • An espresso is a
« Reply #731 on: March 01, 2017, 07:56:09 PM »
It's not needed around the piston. The seal does perfectly well and you want it to be in direct surface contact with the piston to prevent any fluid from weeping past.
The Dow grease is for the back of the pad to prevent pad squealing.
sorry I meant "around" as in might come in contact with.  it will be on the back of the pad which will touch the end of the piston (correct?) I just wanted to make sure the is was still ok to use there considering the new piston material.
« Last Edit: March 01, 2017, 08:00:47 PM by BLAC »
Offline Godffery
  • Godffery's Garage
« Reply #733 on: March 05, 2017, 02:13:34 PM »
I got to meet Bryan aka Blac at his shop this morning.  What an amazing shop space!  The bike looks fantastic in person.  The subframe looks great and Cliff Meyer's seat fits it like a glove.  Parts are coming in and this bike is going to be awesome.
Offline BLAC
  • An espresso is a
« Reply #734 on: March 05, 2017, 05:43:02 PM »
Thanks Don! It was great meeting you today. We will have to take the (running) bikes out for a cruise sometime!
Once I get my crank back from APE, my monoshock from Racetech  and my pistons/cylinder/head back from Mike.. this thing will be coming together pretty quickly.  At a standstill now but I did go through every shaft in the transmission today.
Completely disassembled, cleaned, lubed and reassembled them.
All clean!
« Last Edit: March 05, 2017, 06:26:02 PM by BLAC »
Offline BLAC
  • An espresso is a
« Reply #735 on: March 06, 2017, 10:14:49 AM »
I washed all of these shafts, washers, bearings and gears with a "chem dip parts cleaner" I then rinsed them off and rubbed them down with a light coat of wd-40.  As I assembled them back onto the shaft of which they came, I used a little bit of assembly lube and motor oil (just to keep them coated).
does all of that sound kosher?  just ckecking to make sure I havent done something stupid before I put them back into the cases  :-X
Offline BLAC
  • An espresso is a
« Reply #736 on: March 06, 2017, 11:36:37 AM »
Grazie.  as a first timer going through it I periodically want to check in and make sure I havent done anything silly.
Im trying to avoid things like "YOU WIPED WD40 ON THE TRANSMISSION GEARS!? NO WONDER IT EXPLODED"   :P
Offline Pin2Hot
« Reply #737 on: March 08, 2017, 02:24:29 PM »
I can't believe I haven't come across this build before, great work!  The similarity between our builds is pretty nuts.  I guess we both have great taste.  :)  Subscribed.
Offline paulschell
« Reply #738 on: March 09, 2017, 11:18:03 AM »
Hey Cal,
Where did you pick up your rotor by the CB550 disc conversion? I want to make sure I"m getting the right one as well.
Did mounting hardware also come with your P32 - or did you just have spare hardware?
Paul
« Reply #739 on: March 09, 2017, 01:59:14 PM »
Paul
Its a standard GSXR750 rear rotor spec. Choose any source and spend what you are willing. The caliper hardware was ordered (Devin gave me the specs).
FYI - Cognitomoto's website for the hub identifies a DUCATI Monster 400 600 620 750 800 888 9001000 rotor.  That said, IF Cal says a GSXR rotor fits, they both likely work with the hub.
https://cognitomoto.com/collections/hubs-wheelgoods/products/cb500-cb550-rear-hub-disc-brake-conversion
Offline SKTP
« Reply #740 on: March 09, 2017, 02:58:50 PM »
I have not been following this thread...but seeing your trans gears/shaft there make me want to say that having my trans back-cut was one of the best things I have done to my bike...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline paulschell
« Reply #741 on: March 09, 2017, 03:09:32 PM »
Paul
Noted, thanks fellas. Think this one should work out, unless there are any cheaper ones that I haven't come across (http://www.2wheelpros.com/brembo-oe-brake-disc-245x4mm-ducati-yamaha-2358316.html).
Unfortunately had to send my hub back to Devin as my cush drive dampers were a year newer than what he had manufactured the hub for - he's re-making it though thankfully.
« Last Edit: March 09, 2017, 03:11:28 PM by paulschell »
« Reply #742 on: March 09, 2017, 03:34:50 PM »
Paul
My supplier was $71 shipped.
Offline paulschell
« Reply #743 on: March 09, 2017, 03:37:03 PM »
Paul
Mind if you forward me a link as well? Got to save where I can, #studentlife.
Offline BLAC
  • An espresso is a
« Reply #744 on: March 10, 2017, 01:45:40 AM »
Interesting... I inspected all of the gears and none of the dogs showed any wear (or marks for that matter) so I assumed I would be fine leading them stock.  What about having them back-cut improved the bike so much? Were you having issues with it popping out of the lower gears?
Offline BLAC
  • An espresso is a
« Reply #745 on: March 10, 2017, 02:18:21 PM »
Just got a call from APE, crank and studs are done and being shipped today!
In other exciting news, I am headed to Iceland (for the third time) in a couple months and just ordered this to take with me.. I will be sure to have some tracking/follow shots done once my bike is done also  8)
« Reply #746 on: March 10, 2017, 06:23:31 PM »
In other exciting news, I am headed to Iceland...
Mind if we ask what you will be doing? (Business or pleasure?)
There is a member in Iceland, he has posted some incredibly beautiful pictures of his country.
Offline Camrector
« Reply #747 on: March 10, 2017, 07:02:19 PM »
I was just in Toronto for the International Flyfishing Film Festival. The Iceland submission "The Hidden" was amazing. Science fiction beautiful!
Offline BLAC
  • An espresso is a
« Reply #748 on: March 11, 2017, 12:33:24 PM »
I'm taking my girlfriend with me to celebrate my 30th birthday and our anniversary.  We are rolling them into one shebang.
I have been to Iceland before and it is absolutely the most beautiful, diverse and unique landscape I have ever seen.  Cam like you said it does look alien, when you are there you are constantly saying "this does not look like earth".
I'll dig up some photos of my last couple trips and post them here ;)
Offline BLAC
  • An espresso is a
« Reply #749 on: March 12, 2017, 04:09:50 PM »
As much as it makes the photographer in me cringe posting low resolution version pulled form Facebook and Instagram, my files are at work on a HD, so these will have to do.
Last trip to Iceland:
Geysir:
One day of driving:
I might be on planet Hoth..?
Gullfoss:
Our rental car was pretty cool too ;)
