Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 184582 times)
Offline koendd
Re: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"
« Reply #975 on: April 26, 2017, 10:24:50 AM »
funny #$%*!
looks like the cap of a hondabond/sealer tube
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline BLAC
  • An espresso is a
« Reply #976 on: April 26, 2017, 10:32:58 AM »
That's what I thought when I pulled it out too, I pulled it out and immediately looked for my HondaBond to make sure I didn't do something stupid and put the cap in there haha.. but it is really rubbery and semi translucent..
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline calj737
  • I refuse...
« Reply #977 on: April 26, 2017, 10:35:41 AM »
Dude! Now you're screwed... that cap is supposed to be in there  ::) Stinking amateur wannabe motor builders! You could screw up a 2-car funeral or tear up an anvil with a rubber mallet. Start over please and put that back where it belongs, cemented in place with Permatex.
Geez my patience is wearing thin-  8)
Offline BLAC
  • An espresso is a
« Reply #978 on: April 26, 2017, 10:38:41 AM »
 ;D ;D ;D I do what I can!
but... that isnt supposed to be in the motor at all.. is it? I have looked at 3.2 million engine schematics and forum threads and can not find a mention of this thing.
The only thing I can think of is maybe it is a cap used to protect threads when vapor blasting?
« Last Edit: April 26, 2017, 10:41:54 AM by BLAC »
Offline calj737
  • I refuse...
« Reply #979 on: April 26, 2017, 10:40:54 AM »
It's from the uber-rare Sandcast 550 cases, made only 1 day in the month of April, and only 19 documented cases had it. You've just devalued that bike immensely. Please erase that post, put it back, and Trey pretend like it never came out. We won't tell when you go to sell it  ;)
No, doesn't belong, and no, it's not from Vapor Blasting either.
Offline BLAC
  • An espresso is a
« Reply #980 on: April 26, 2017, 10:43:13 AM »
 ;D ;D ;D ;D
Offline BLAC
  • An espresso is a
« Reply #981 on: April 26, 2017, 10:59:08 AM »
Mystery solved, it was a thread/hole protector from the vapor blasting process.
I might have blown it in farther down into the hole with my air compressor, but either way I should have chased the threads and found it earlier.
All good, mystery solved  ;D
« Reply #982 on: April 26, 2017, 10:30:51 PM »
That's just mean!
Offline BLAC
  • An espresso is a
« Reply #983 on: April 26, 2017, 10:39:52 PM »
That's just mean!
Such a nice guy, right?!  ;D
Offline BLAC
  • An espresso is a
« Reply #984 on: April 26, 2017, 10:53:53 PM »
Cylinder is on and pistons are sittin pretty!
Offline Restoration Fan
  • My wife will never call me
« Reply #985 on: April 27, 2017, 12:04:25 AM »
Man, that engine looks good!  Great job on this bike, Bryan!
Offline BLAC
  • An espresso is a
« Reply #986 on: April 27, 2017, 10:03:47 AM »
Thanks Ron!  I am about to put your valve cover to work once I need to degree the cam.  I will engrave "Restoration Ron's Good Karma Cam Cover" on it and over it up to other 550 owners once it is milled out =)
thanks again!
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #987 on: April 27, 2017, 10:25:07 AM »
thanks again!
So you got yourself a Mega 126-00 cam?
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline BLAC
  • An espresso is a
« Reply #988 on: April 27, 2017, 10:37:42 AM »
I think I'm going with the 126-20  ;D
« Reply #989 on: April 27, 2017, 03:05:33 PM »
Nice job...no matter what Cal says!
Offline Camrector
« Reply #990 on: April 27, 2017, 05:00:52 PM »
I'm pretty sure I've mentioned it before, just make sure those valve reliefs are big enough for the 126-20. They don't appear to be now.
Offline BLAC
  • An espresso is a
« Reply #991 on: April 27, 2017, 06:06:17 PM »
Yep, I'm going to outsource that.  No reliefs have been cut (beyond factory) on these pistons
« Last Edit: April 28, 2017, 11:17:43 AM by BLAC »
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #992 on: April 29, 2017, 03:24:44 PM »
How is that done Cam?
« Last Edit: April 29, 2017, 06:53:45 PM by NobleHops »
I have a motorcycle problem.
Offline calj737
  • I refuse...
« Reply #993 on: April 29, 2017, 05:39:47 PM »
They will look like this when done-
Offline BLAC
  • An espresso is a
« Reply #994 on: May 03, 2017, 06:13:44 PM »
Just got some 520 chain conversion sprockets ordered from Sprocket Specialists
Im thinking this chain is too pretty not to buy  :P  Anyone have experience with the lightweight '3D' 520GP chain from EK?
« Last Edit: May 04, 2017, 05:14:23 PM by BLAC »
« Reply #995 on: May 04, 2017, 04:33:07 PM »
EK makes good chains, no experience with the 520GP.
David
Offline BLAC
  • An espresso is a
« Reply #996 on: May 04, 2017, 04:34:11 PM »
David
I hope it ends up being worth the cost, because I already ordered it  ;D
« Reply #997 on: May 04, 2017, 08:27:10 PM »
Ask bwaller, Brent, what he uses on his race bike, I think he uses the 520.  It is a almost elegant design.  What did the sprocket sets cost you?
Just curious if the 520 ends up being more expensive than  the 530 chain and sprocket set.
But, I imagine this 520GP chain costs more than a standard 520 chain would cost.
Does 4 into 1 carry EK or was it DSS I looked at pricing some things the other day.
South Sound Honda in WA state in Olympia are has good prices if ordering Genuine Honda.  Some of the CX and GL owners on that forum have reported very good prices and shipping charges have been very reasonable as well, even on small orders.  They found their discount to be either the best or close to the best and the shipping made up for it.
Worth taking a look at....
So, pack a few bologna sandwiches for work instead of going out to eat if you normally would...or skip the Starbucks or coffee shop and you will soon have saved the amount you spent extra on that chain...
Or, buy a container of chocolate whey protein and have a 20g protein shake instead of lunch and you are likely to easily shave a few pounds of weight over the course of a month or two at the most...every pound you trim off your body will be that much less on the bike, which if racing pays dividends on the track.  Easier to trim 5-10 pounds off your body than it is your bike.
Your spouse or girlfriend is likely to hate you for how easily you can drop weight...at least that will be true until you hit your 50s and higher when changes in your body start making it harder to lose weight than it " used to be"...
Offline BLAC
  • An espresso is a
« Reply #998 on: May 04, 2017, 08:53:11 PM »
The sprockets (front and rear) ended up being $120 shipped to my door after I spent up to have it anodized/machine polished (around the speed hole lips).
The chain retails around $350 but I found a pretty decent price on amazon (the last one available through the EK store) and with a gift card I had laying around I think I ended up paying another $130 out of pocket... still a damn expensive chain, but there should be significant weight savings between the steel stock sprocket and chain vs this setup, additionally the nickle plating/polishing on this chain is beautiful.
I'll do a weight comparison of the two setups sode by side and see how many pounds I saved for ~$250  :o ;D
Offline slikwilli420
  • Master of Disaster
« Reply #999 on: May 05, 2017, 05:20:19 AM »
Plenty of nice 520 chains for well under $100. I'm using a DID520vx2 that is high tensile, x ring and cost about $70.
