Author Topic: 75 Super Sport Pistons  (Read 12077 times)
Re: 75 Super Sport Pistons
« Reply #50 on: February 28, 2016, 07:50:17 PM »
Maybe to help defray some of the confusion:
The OEM compression of the K0-K6 engines is 9.0:1.
The OEM compression of the F0/F1 engines is 9.2:1 (despite some of the ads Honda put out, showing it higher).
The OEM compression of the K7/K8 engines is the same as the F0/F1.
Installing the 836 CruisinImage pistons in the F0/F1/K7/K8 engines makes the compression just over 9.0:1, IF the quench band is cut into the head to match the bores. If not, the compression is nearer 9.25:1, but breathing is restricted a little bit.
Installing the K0/K6 pistons into the F0/F1/K7/K8 engines brings the compression down to about 8.8:1. On most of these heads there is room to mill off the 1mm extra height applied to the combustion chambers, bringing them back down to the size of the K0-K6 chambers. This brings the compression back up to about 9:1 again. Some riders worry about "valve clearance" in this conversion, but my clay-on-top-of-the-pistons tests have showed this clearance to be more than 2mm in all cases.
If you take some DOHC 750 pistons (1979-1982) and trim their shoulders down 1.5mm for about 6mm in from the outer edges, the compression comes to about 9.6:1 in the end, and the bore size is +1.0mm over stock bores (760cc).
« Last Edit: March 04, 2016, 08:34:54 PM by HondaMan »
Offline RodSOHC750
  • Restoring Vintage Honda Motorcycles
« Reply #51 on: March 01, 2016, 10:33:00 AM »
I happen to have a used piston I replaced from my 1979 750LE DOHC engine.  Note the high ridge along the center of the piston top. Will this interfere with the head?
Picture below are of the new 1975K piston and the 1979LE piston.
1979 Honda CB750L Limited Edition
1975 Honda CB750F Super Sport
1972 Honda CL450
1970 Honda CT70
Offline BPellerine
« Reply #52 on: March 01, 2016, 12:35:58 PM »
they would give higher comp in early f or k,and maybe clearance issues.billp
1978 CB 750K ard and webers
another anfob
« Reply #53 on: March 01, 2016, 03:51:30 PM »
The -392 F/F1 pistons ARE different than the -392 K7/K8 pistons. The F has a 'full' dome and will give a slight compression bump over the K7/K8. I have posted comparative pictures somewhere.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #54 on: March 01, 2016, 03:54:53 PM »
Should be no clearance issues with the flat tops. Poised to install some "dolled up" cruzinimage 65mm into my K8:
 ;)  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #55 on: March 01, 2016, 04:03:07 PM »
 ;)  8)
Looks like DFL coating on the skirts!
« Reply #56 on: March 02, 2016, 07:41:21 PM »
You must cut down the whole crown from around the edge to about 6mm inward, about 1.5mm deep, to let them fit the K7/8 or F0/1 heads. I did one of those last Spring.
Offline RodSOHC750
« Reply #57 on: March 02, 2016, 11:26:15 PM »
Just to make sure I understand correctly, here is a sketch of the piston modification.  In correct machinist terms, this would be a 1.5mm x 6mm chamfer all-around.
« Last Edit: March 02, 2016, 11:44:43 PM by RodSOHC750 »
1972 Honda CL450
1970 Honda CT70
« Reply #58 on: March 04, 2016, 08:43:11 PM »
Here's the ones I did last Spring. The -392- piston is on the left in each shot, the modified DOHC on the right.
« Last Edit: March 04, 2016, 08:45:36 PM by HondaMan »
Offline RodSOHC750
« Reply #59 on: March 05, 2016, 10:57:23 PM »
Thanks for the photos of the DOHC piston modifications.  I don't see any problem boring 1.0 mm oversize and netting a slight increase in compression ratio (9.6 vs 9.2).  I would need to also order rings for a 1979 DOHC 750 standard bore.
1972 Honda CL450
1970 Honda CT70
Offline RodSOHC750
« Reply #60 on: March 28, 2016, 11:34:15 PM »
Just an update on my progress.  I bought eight used 1979 Honda CB750 DOHC pistons off of Ebay.  I'm taking them to a shop this week to have the top edges beveled 1.5 x 6 mm.  Four pistons are for me and the other four (if they turn out to be good condition) will go to my son for a future rebuild.
1972 Honda CL450
1970 Honda CT70
