Author Topic: Will Vaseline help me get it in there?  (Read 7705 times)
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
Re: Will Vaseline help me get it in there?
« Reply #25 on: November 09, 2006, 07:31:44 AM »
I use long woodworking clamps to pull them on or pull them off.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
ktp1598
« Reply #26 on: November 09, 2006, 08:20:21 AM »
Since we are on the topic of carb boots, can any of the experts out there (I'm a rook) pipe in on alternatives (if any) on having to purchase these carb boots from the dealer?  It looks like I will need to replace mine.  I inquired from the dealer as to cost and availability and I just about crapped my pants when I heard what these would cost?
Thank you in advance for any feedback.
I'd like to know too...
« Reply #27 on: November 09, 2006, 08:20:29 AM »
...lay on it with the heat gun until they are soft enough...the head gets pretty hot, so I don't think you have to worry about damaging the boots...if you se smoke, then stop...   ;D
Mreick got me a new set for a reasonable price. The clamp were very pricey. The new boots are so much softer.
O intake they actually pulse, looks like little hearts beating at idle.
Stumby
« Reply #28 on: November 09, 2006, 09:03:38 AM »
...sounds painfull.
I just spit on em.
 ;D
rt
« Reply #29 on: November 09, 2006, 09:38:35 AM »
show them a pic of Chantelle Houghton - those boots won't stay hard then... ;D
Offline Klark Kent
« Reply #30 on: November 09, 2006, 03:28:17 PM »
aye, and bless those little hearts.
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline jtb
  • An unlikely
« Reply #31 on: November 09, 2006, 06:47:43 PM »
I swipe a little bearing grease on mine.  I got a new set from Service Honda, they were about $16.00 apiece, and well worth it.
1977 CB750F
1985 V65 Sabre
Offline schneider419
« Reply #32 on: November 12, 2006, 05:43:27 AM »
well here i am at the end of  the line again. any way for what it's worth, when i put the carb. rack on my 350/f, i spray a little honda shine, the stuff you use to shine up your bike, into the boots. wipe it around a little. it really helps ease them in. done it for years, no problems
Boomologist
« Reply #33 on: November 12, 2006, 10:08:53 AM »
I use a little WD40. Over time it seems to be absorbed by the rubber.
Also, I have seen old rubber that is in contact with engine oil become very soft and split.
It's too bad some company doesn't invent something that will replace the oils that rubber looses.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #34 on: November 12, 2006, 11:55:18 AM »
I hit the rubber bits with some silicone spray now and again, it seems to help.
Offline cleveland
« Reply #35 on: November 12, 2006, 05:10:27 PM »
I ended up using both a heat gun and oil.  The carbs have not been on the engine for a long time (maybe a year or two) so I think that played a part in them not wanting to go on.  I think they shrunk some because my other set were not nearly as hard to get on.  The funny thing is the air box won't fit, so I have to pull them off and re-jet the carbs for pods.
