Author Topic: Help to analyse compression test results  (Read 10012 times)
Offline bochnak
    • How-To Motorcycle Repair Blog
Re: Help to analyse compression test results
« Reply #50 on: February 01, 2016, 11:47:25 AM »
Emulsion tubes were never sold as an individual part.
Unless yours are severely damaged, yours can and should be reused.
Yes and no, depending on the model. I reuse them if I can. I have seen some worn from the needle, again not speaking to any particular model. In cases like those, I have used Keyster kits w/o any problems because I didn't have any other options. I was just trying to get feedback on Keyster brand from you guys.
« Reply #51 on: February 01, 2016, 11:52:43 AM »
I learned my lesson tuning my 350F.   Its Keihin only for me, now.
Shouldn't the needle jet prevent any wear on the emulsion tube?
Offline bochnak
« Reply #52 on: February 01, 2016, 12:04:44 PM »
Here is an image from the web and shows the wear due to needle:
Offline grcamna2
« Reply #53 on: February 01, 2016, 12:28:16 PM »
That piece looks like the needle jet which will come included w/ a new oem needle in the bag;sometimes the emulsion tube has the needle jet attached as one-piece..
Offline grcamna2
« Reply #54 on: February 01, 2016, 12:29:52 PM »
Hi Guys. Good news. Bike is behaving very good ! I run two hours in the last two days and it starts from cold without the need of any spray.
Great....sooo, what fixed it?
_mark,
How did you acheive the smooth running/idling on your bike ?
« Reply #55 on: February 01, 2016, 12:32:24 PM »
bochnak....good pic, and ive seen it before.
The needle jet is where the majority of the wear would occur as it centers the needle in the emulsion tube.
Offline _mark
« Reply #56 on: February 02, 2016, 08:09:18 AM »
_mark,
Hi guys thenks and sorry for delay of the aswer but I was busy to run the motorbike.
I simply run for some hours also in motorways and to keep high revs as adviced by my mechanic (make some gym to engine...) and then I tried two mornings to start (5° celsius)  without the help of the fluid and motorbike starts at the second foot kick (I don't use the starting motor to avoid to deplet battery).
Motorbike in my point of view is very good; run ups very fast ... but consider I'm a newbie of motorbikes so my opinion are not so considerable...
Is it normal that minimum RPM is higher in hot conditions (about 200 rpms more) ? I can mantain a setting of 1000 RPMS in hot conditons but when I start from cold I need to hold the throttle.
Thanks.
« Last Edit: February 02, 2016, 08:13:19 AM by _mark »
« Reply #57 on: February 02, 2016, 08:26:02 AM »
Thanks.
Yes, this is normal.
Glad its running well
Offline grcamna2
« Reply #58 on: February 02, 2016, 09:49:24 AM »
_mark,
Would you make a small video of the engine running at idle speed after you come back from your ride ?
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=21dacph7emvkh3c9l4mern0fj2&/topic,60973.0.html
« Reply #59 on: February 02, 2016, 10:01:01 AM »
if all are adjustet perfekt..ther first1/3 choke is only give ca 100 rpm..and no real choke..first from half choke it Locks the choke ports..but its only on 77/78 kabel shoke kaburettors...vho have this smart ekstra help.
.on the pre 77 modells,,, handel operated choke,, the gas must be adjusted by trottel turn the handel..
i hate all this v-w.... vords
Offline _mark
« Reply #60 on: February 03, 2016, 05:59:33 AM »
Thanks.
sadly in these days is raining. I will post when I can start and run.
Thanks.
Offline jonda500
« Reply #61 on: February 04, 2016, 02:30:03 AM »
Mark -  A few comments:
I am not convinced your Mechanic properly cleaned your carbs for 2 reasons: If fully and properly cleaned, the bike would not require a "starting fluid". And, if the carbs are not fully cleaned, it is also possible that the slides are not synchronized and thus, your compression readings will also be negatively effected.
All your reports from riding indicate a poor state of tune and dirty carbs. Get these things done personally or professionally with a guarantee of their results.
There is no benefit to using higher octane fuel in these bikes. The stock compression ratio is about 9.2-9.5:1. This is very well suited to 89 octane. Higher octane fuel only produces benefit with higher compression engines. A fuel additive like "SeaFoam" while beneficial for daily/seasonal treatment of your fuel for Ethanol-based fuels will do virtually nothing for carbs that are not cleaned properly. SeaFoam will not dissolve varnish from fuel evaporation due to prolonged storage.
Compression tests should be performed with the throttle held wide open - as such readings will not be affected by poorly synchronised carbs.
SeaFoam or similar products are exactly what I use to dissolve varnish left from fuel evaporation?
John
A starter clutch thread:
Offline _mark
« Reply #62 on: February 04, 2016, 08:25:45 AM »
_mark,
Offline _mark
« Reply #64 on: February 04, 2016, 08:50:18 AM »
now is public  :D
« Reply #65 on: February 04, 2016, 08:58:20 AM »
sounds great!  I bet you could comfortably drop the idle even more.
Offline _mark
« Reply #66 on: February 04, 2016, 09:05:26 AM »
Yes, I will   ;)
Offline bochnak
« Reply #67 on: February 04, 2016, 09:22:37 AM »
I agree, sounds good. Drop the idle to 1100 or so.
Just sounds like you have to figure a good procedure for starting and warm up. Every bike acts a little different and you'll have to find out what makes it happy  :)
Offline grcamna2
« Reply #68 on: February 04, 2016, 09:40:11 AM »
That sounds nice and smooth  :)
