Author Topic: removing forks on 76 750 pretty straight forward?  (Read 1770 times)
Offline trent
« on: January 30, 2016, 06:40:56 PM »
I'm preparing to remove the forks and rebuild them. I have never done this, but I have done most everything else on a bike in the past. Is it as simple as it seems? Thanks for any input.
Offline Steve_K
Re: removing forks on 76 750 pretty straight forward?
« Reply #1 on: January 30, 2016, 07:14:11 PM »
Hardest thing is to support the bike when removing forks.  I like to loosen the fork caps first while still in triple tree.  Keep fork caps in until the allen bolt holding the damper is removed.  Consider draining fork oil before removing the allen bolt.  The manual has good info on this.
Steve
Steve_K
« Reply #2 on: January 31, 2016, 12:20:11 AM »
Steve
this is all good info
Offline DohcBikes
« Reply #3 on: January 31, 2016, 05:38:34 AM »
Crack the Allen's loose with the weight of the bike on it before you do anything else. have a catch can handy.
There's a solution to every problem.
Offline robvangulik
  • Honda Fourever
« Reply #4 on: January 31, 2016, 06:25:44 AM »
That will be a bit hard to do, as the axle has to be removed to get to those Allen bolts.......
Offline DohcBikes
« Reply #5 on: January 31, 2016, 06:30:47 AM »
Ahh yes, straight forks. My mistake.
« Reply #6 on: January 31, 2016, 07:30:19 AM »
Best, safest way is to lift the entire front end off the ground.
I have a pice of angle metal bolted to the ceiling joists and attach a 4" wide strap to hoist the front end of the bike.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=rpikj3v4jfah01j7i4c7snhs37&/topic,60973.0.html
« Reply #7 on: January 31, 2016, 07:39:26 AM »
on my cbx and 550..i just pulled the lower legs..just take front hveel calibers..and spedo kabel...and let all rest be on..light housing andall that rubber parts is hell to Work on...if stering bearings are ok..just let all stuff be on the bike
« Last Edit: January 31, 2016, 07:42:35 AM by strynboen »
i hate all this v-w.... vords
Offline Steve_K
« Reply #8 on: January 31, 2016, 01:39:04 PM »
I use front a front wheel stand that goes into the triple tree.  Need to also use a rear stand or some can use the center stand  with the front wheel stand.   I needed that stuff for my sport bikes, so some people would not have those stands.  The other guys have very good ideas and if I did not have my stuff that is what I would do.
Steve
Steve_K
Offline trent
« Reply #9 on: February 01, 2016, 02:18:21 PM »
Thanks for the help! Also very good info on Youtube. I dismantled everything, installing new neck bearings, undecided if I will install new or another used set of fork tubes, they aren't bad, but a bit rough on the part that will be visible now that the headlight "ear" assembly is not going to be used. I guess we'll see how it all works out..
Offline strynboen
« Reply #10 on: February 02, 2016, 06:48:42 AM »
you can Mount some crome  or/ss tubes autside the orginal tubes,,just put some o rings inside to hold them stabel..then the good looks is forever
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #11 on: February 03, 2016, 11:10:39 AM »
Just remember, when bolting everything on the triple tree back up, make sure the front wheel is pointing straight and the fork tubes are even.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Mr Freeze
« Reply #12 on: February 03, 2016, 02:15:23 PM »
If you're a drummer, a cymbal stand without the top works perfectly. I caught the edge right behind the lower triple tree on the frame and raised the height of the stand until I could slide the forks out. Once you are done rebuilding, reinstall the forks, then get the wheel into position and slowly loosen the stand to drop the forks onto the axle.
