Author Topic: creak/squeak noise at startup, complete engine teardown help needed!!!  (Read 4515 times)
Offline MatteoP
Re: creak/squeak noise at startup, complete engine teardown help needed!!!
« Reply #25 on: February 02, 2016, 07:36:54 PM »
So I took a look at the stator, and all the bolts are tight, and everything is firm. I noticed a weird wear mark, but I am not sure if that is just like that. Also it has a lot of surface rust, should I clean that up nicely while I am at it? Below some pics.
I also took a closer look at the cam chain tensioner, and it seems ok apart from some marks towards both ends, is that something to worry about? Pics also below.
Should I exclude the option of crank bearing or they still are a possibility?
a failing/failed starter clutch will make a shrill squeek or chirp and it is quite possible for it to stick engaged after the starter stops spinning
I wasn't able to take a video so I tried to find similar sounds, but what you are describing really does sound like what I was hearing. Can I access and repair the starter clutch without splitting the case?
Thanks so much for everyone so far!
Offline MatteoP
« Reply #26 on: February 02, 2016, 07:38:54 PM »
here the cam chain tensioner
Offline grcamna2
« Reply #27 on: February 02, 2016, 09:39:25 PM »
The top pic in your second to last post does look like the stator/flywheel was rubbing on something,any more pics of the inside of the outer stator/field/windings where the rotating wheel fits inside ?
DH
« Reply #28 on: February 02, 2016, 10:25:50 PM »
+1 above and...is the bolt tight? if you want to check starter clutch, to see if locked up in both directions, check the link below
http://forums.sohc4.net/index.php/topic,43117.msg448671.html#msg448671
« Last Edit: February 02, 2016, 10:28:09 PM by DH »
Offline jonda500
« Reply #29 on: February 02, 2016, 10:37:24 PM »
I have to disagree - that stator looks quite normal to me. Though not always so rusty, they all look like that, it's something to do with the manufacturing process.
John
A starter clutch thread:
Offline grcamna2
« Reply #30 on: February 03, 2016, 06:03:35 AM »
John
I stand corrected,thanks John
Offline MatteoP
« Reply #31 on: February 03, 2016, 06:36:56 PM »
I checked the gear through the hole where the started goes in... the gear spins freely to the left (towards the front of the bike), I also checked the starter itself and that spins both ways (not sure what it is supposed to do).
Below the pictures of the gear and starter.
Does that mean that my starter clutch is most likely fine?
I found a good DIY to fix the starter clutch without splitting the case:
http://forums.sohc4.net/index.php?topic=122084.0
I'm going back to the crank bearings idea thrown out before, are those a possibility, as far as the noise I was hearing?
Offline MatteoP
« Reply #32 on: February 03, 2016, 06:38:22 PM »
forgot to mention the gear does not spin at all in the other direction (gear inside the case).
DH
« Reply #33 on: February 04, 2016, 06:43:27 AM »
sounds like your starter clutch is ok then, that's how its supposed to work.
