Author Topic: CB550 Motor Build  (Read 17977 times)
Offline akabek
Re: CB550 Motor Build
« Reply #75 on: June 10, 2016, 08:54:56 PM »
The Cycle x adapter can also use vacuum ports to sync the carbs.
I am using a 1975 CB550F tank and with the Power-Barn setup there is a little interference between the petcock and the carbs.  I just lift the tank up slightly to open the petcock.  If the Cycle x adapter is shorter than the Power-Barn setup you may experience the petcock hitting the top of the carbs.  Something to consider.
« Last Edit: June 10, 2016, 09:05:09 PM by akabek »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #76 on: June 10, 2016, 10:18:15 PM »
Well they do not have any o rings cut into the back where they attach to the head. So we both want to know how they seal up. Maybe they want me to use some kind of RTV? Or break out a rotary table and cut them myself? So we will see what Ken says. I'm going to send Mike my stock manifolds to port match just in case.
The CycleX manifold looks like a cheap copy of the FunJimmy Racing manifold. FJR manifolds have o-ring channels and are back milled to reduce weight. They also have recess socket cap fasteners. Maybe ask Ken where he got the design.
Remember that the two manifold options require different carb spacing.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #77 on: June 10, 2016, 10:26:24 PM »
Yup. That's a valid concern. My interference problem was solved by removing the stock petcock and using an inline fuel tap. No reserve though so keep an eye on your trip meter.
Before
After
Offline Camrector
« Reply #78 on: June 11, 2016, 05:38:07 AM »
Thanks guys, and yes I'm well aware of the possible clearence issues. And Fj that's exactly what these manifolds don't have, Oring channels.
I plan on using the V stacks with a sock instead of the pod filters, will clearence with the stock manifolds still have the interference?
Offline akabek
« Reply #79 on: June 11, 2016, 01:51:53 PM »
I am running the Power Barn CR26 kit.  I have used stacks with ITG filters as well as pods.  I have a cb550 tank and you can see the fuel petcock lever has interference.  I can lift the tank enough to rotate the lever.
« Last Edit: June 12, 2016, 05:04:41 AM by akabek »
Offline Camrector
« Reply #80 on: June 11, 2016, 06:15:08 PM »
Here you guys can see the concern with the intake manifolds
and this is what their eBay description states.
i guess we shall see.
Offline Camrector
« Reply #81 on: June 12, 2016, 08:02:14 AM »
Akabek Why not cut off the petcock switch a bit were it interferes?
Offline akabek
« Reply #82 on: June 12, 2016, 10:39:58 AM »
I can easily lift the tank slightly to clear the carbs.
Offline Cityscapedview
« Reply #83 on: June 12, 2016, 10:53:21 AM »
Subscribing to this one.
The work you've had done is inspiring, can't wait to see this beast of an engine when she is complete.
1971 Honda CB 500
David
Offline Camrector
« Reply #84 on: June 14, 2016, 09:28:48 PM »
So after speaking with Ken at cycle X he recommended Hondabond for sealing the(CycleX) intake manifolds to the head. I think though that I'll cut a oring channel instead. Also I am thinking of experimenting with a phenolic plastic spacer, between head and manifolds. That could serve two purposes. Reduce/eliminate heat transfer from head to carbs, and provide clearance room if petcock becomes an issue. Thoughts gents?
« Last Edit: June 14, 2016, 09:40:39 PM by Camrector »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #85 on: June 14, 2016, 10:38:56 PM »
The rubber manifold boots will control the heat issues.
Petcock interference might be lessened with additional manifold length.
You'll just have to mock up and see.
Online RAFster122s
« Reply #86 on: June 16, 2016, 02:06:15 PM »
Would adding a phenolic spacer cool the intake manifolds slightly... Whereas direct connect to the motor would heat them and they would help vaporize any liquid fuel that contacts them.  I've seen phenolic spacers typically used between the carbs and the intake manifolds on cars as the higher heat of the motor is going to push the phenolic's heat range. Phenolic is often using epoxy and unless it is a high heat epoxy you are looking at what 400F being the heat range?
Offline Camrector
« Reply #87 on: June 16, 2016, 05:00:51 PM »
Yes Raf I was thinking of mounting a phenolic spacer between the intake manifolds and carbs.
Offline schroederb2007
« Reply #88 on: September 26, 2018, 01:50:43 PM »
Bump! Any further progress on this?
Offline Camrector
« Reply #89 on: September 27, 2018, 12:59:14 PM »
Motor is all done, and ready to rock. Need to put the bike together over the winter. I’ll start a build thread once I get going.
Offline Camrector
« Reply #90 on: September 27, 2018, 01:02:59 PM »
Online RAFster122s
« Reply #91 on: September 27, 2018, 10:40:20 PM »
Very nice Cam!  Pretty monochromatic but that is how they were out of the factory...  Do you have a concept of what the color scheme is going to be in the end?
David
Offline Camrector
« Reply #92 on: September 28, 2018, 04:51:55 AM »
I think this one is going to look like you ran the entire bike through Nils’s vapor blaster. ;D
