Author Topic: Float bowl gasket  (Read 1497 times)
Offline parm94
Float bowl gasket
« on: January 31, 2016, 10:29:27 pm »
We all know how much of a pain those circular gaskets are. I saw these shaped ones on eBay and was wondering if anyone has tried them out. Do these fit well?
http://www.ebay.com/itm/honda-1970-77-cb550-cb550f-cb500-k1-k2-k3-k4-carb-carburetor-FLOAT-BOWL-GASKET-/291653659925?fits=Model%3ACB550F&hash=item43e7e9ad15:g:A-kAAOSwRLZT9nFT&vxp=mtr
Re: Float bowl gasket
« Reply #1 on: February 01, 2016, 06:49:04 am »
These work great too, and are made of viton, for only  $11
http://4into1.com/shaped-o-ring-float-bowl-gaskets-4-pack-honda-cb350f-cb400f/
Offline Redline it
  • thread killer
« Reply #2 on: February 01, 2016, 11:34:47 am »
probably a killer deal for $11.00, but crazy. about 3 bucks each with shipping. It's a part that might cost under .10Cents each to manufacture. Being a bit more hillbillyish I get oring just slightly undersized od, add a trace of contact cement on the corners of the bowl and lay them flat on a piece of glass so I can see it,  clamped over night it'll learn a set to buy you some installation time. I think the orings are available at a bearing store in a package that cost 1.00 and some change. get the fuel resistant kind. and if you take them apart in the future, an oring might start to pop out of its recess, dry it and add some contact or neoprene glue at the corners again very lightly, and it stay's in place to assemble. contact cement is getting expensive. Neoprene glue for wetsuits is still pretty cheap.  nobody will ever know.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: February 03, 2016, 11:14:32 am »
they work perfect. I bought 2 sets way back when. I got tired of wrestling with the basic o-ring in the float bowls.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline riverfever
« Reply #4 on: February 03, 2016, 11:26:27 am »
Yep I just bought a set of those a few months back to put a spare set of carbs all back together. They worked great.
Offline ChopSticks
« Reply #5 on: February 03, 2016, 11:56:20 am »
What do the "circular" gaskets look like? and why are they a pain?
Is there a reason not to just use these ones?
http://4into1.com/float-bowl-gasket-16129-268-004-honda-cb72-cb77-cb750/
« Reply #6 on: February 03, 2016, 12:01:07 pm »
What do the "circular" gaskets look like?  circles and why are they a pain? its a round peg square hole thing ;D
yeah...the gaskets you listed arent for his bike.
Offline ChopSticks
« Reply #7 on: February 03, 2016, 12:57:15 pm »
welp that makes so much more sense now  :-[
« Reply #8 on: February 03, 2016, 01:18:34 pm »
When you buy round gaskets...
and try to put them in a bowl that isnt round, like these PD carb bowls....
...you have to resort to glue/tape monkey business because they tend to not want to stay in the grooves, are the wrong size, can get pinched and leak, or fold inward and cause your float to hang up.
Buy gaskets that fit your bowl groove.
You posted bowl gaskets for an early CB750, the OP has 500/550 5 sided bowls.
Offline parm94
« Reply #9 on: February 03, 2016, 02:15:08 pm »
Yeah I bet lol. I'm going to avoid any glue because it tends to leak into the carbs and clog up the jets from my experience.
Offline Gene
  • Chat enuf you too can be a
« Reply #10 on: February 03, 2016, 02:21:36 pm »
Yep.  Agreed.  Incredibly worth it, to me.
*1973 CB750K3 (Bow)
Offline parm94
« Reply #11 on: February 03, 2016, 02:25:46 pm »
When you go to pull the tape and it rips inside the bowl  :'(
Offline parm94
« Reply #12 on: February 03, 2016, 02:30:28 pm »
Thanks everyone! Going to order a couple sets. No more dicking around with these rings
Offline Gene
« Reply #13 on: February 03, 2016, 02:59:33 pm »
Yeah - even painter's tape.  Then you have to pull 'em all over again.
*1973 CB750K3 (Bow)
