Logo merchandise is available at the SOHC/4 Shop
I'm doing an 836 F3 upgrade and want to confirm the copper washers install on cylinder bolts 5, 6, 7 & 8 under the acorn nuts.When I disassembled the motor, the copper washers were on bolts 11, 5, 7 & 9.
Quote from: 70CB750 on February 03, 2016, 04:50:48 AMTorque chart:Are those torque settings with consideration of anti-seize? or should you set it 30% lower to 10.15 - 12.67 ft-lbs?
Torque chart:
