Author Topic: more carb problems  (Read 606 times)
Offline irish44395
more carb problems
« on: February 01, 2016, 01:46:23 PM »
Putting together carbs 1&2 I am following this http://www.cb750c.com/publicdocs/SeanG/Honda_Carb_Manual_revG.pdf they are not the exact carbs but very close I have a 650 1982 night hawk.
The problem is that I put in the choke shaft just like describe and when I check to see if it works, it. don't. I pull on where the cable goes and it just turns  here are a few pics of what I  got
thanks any help will help
Pete
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline irish44395
Re: more carb problem (up date)
« Reply #2 on: February 02, 2016, 01:42:35 PM »
figured out that the choke shaft is got a little bend to it . Don't know how I did it most likely taking the plates off or on but now I have to see if I can find a new one or straiten out this one . the one on my extra carb bank is also bent worse than the good one . Thanks for all the info madmtnmotors
Pete
