Author Topic: Brake piston  (Read 817 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Brake piston
« on: February 03, 2016, 07:11:59 pm »
So bled my front caliper with a pump. Started to fill lines and again and and good clean fluid coming from nozzle. However, the piston isn't moving and looks cock-eyed. Guessing it's time for a clean and reseal?
Am I on the right track?
Sent from my SM-N900V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=908b5l3b890pdegchlraaacdn3&/topic,60973.0.html
Re: Brake piston
« Reply #1 on: February 04, 2016, 09:12:18 am »
just pop it aut..and thek for korosion..if fine..just replace the sealing..low kost job
i hate all this v-w.... vords
Re: Brake piston
« Reply #2 on: February 04, 2016, 09:21:33 am »
Yes.
A new seal, and potentially new pads and caliper piston.
This is one of those parts that helps keep you alive, and should not be done half-@$$ed.
DH
Re: Brake piston
« Reply #3 on: February 04, 2016, 12:26:28 pm »
+1 to the above. The crud that is probably in there can corrode and jam everything up. It'll be apparant when you separate the caliper halves.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Brake piston
« Reply #4 on: February 04, 2016, 03:08:52 pm »
Yep. It was crud. Got it out. Needs new pads. Piston looks nice. Is the top of piston removable?
Gus, Austin, MN.
DH
Re: Brake piston
« Reply #5 on: February 04, 2016, 04:40:42 pm »
My 750k has a dome shape cover that fits into the open end of the piston. My550k has a solid piston with no open end.
