Author Topic: Let's talk torque wrenchs  (Read 6054 times)
Offline Sockeye
« on: February 04, 2016, 09:32:51 PM »
So in preparation to have the right tools, I need to get a set of torque wrenchs(inch and foot).
 I don't want to spend on the Snap-on level but don't want the cheapo China brands.
What the middle of the road?
'76 CB750F
'97 VF750C
Offline Davez134
Re: Let's talk torque wrenchs
« Reply #1 on: February 04, 2016, 10:40:12 PM »
I have good experiences with Lowes (kobalt) torque wrenches. I've compared their readings with my digital Snap-On and they are pretty consistent and reliable.
« Reply #2 on: February 04, 2016, 10:54:25 PM »
 Hot rod tested a bunch of them and the Harbor Freight cheapies tested well. How long they are accurate I can't say. They were shocked at the results.
Offline mrfish2
  • I might be a
« Reply #3 on: February 04, 2016, 11:19:26 PM »
My Pittsburgh wrench from Harbor Freight has held up well for the past year, and has proven to be fairly accurate.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
« Reply #4 on: February 05, 2016, 03:03:05 AM »
I'm convinced I got good wrenches for not that much. Wrong torque can cost more to repair than the wrenches.
Hazet wrenches, Made in Germany. (Not China or Zimbabwe....)
http://forums.sohc4.net/index.php/topic,148109.msg1687529.html#msg1687529
I was not aware of how much they should be used :-)
Offline calj737
  • I refuse...
« Reply #5 on: February 05, 2016, 03:50:41 AM »
The only advice I'll give you about tools is that they should be considered an investment. Cheap tools break, and they have to be replaced far more frequently than their more expensive counterparts. Torque wrenches especially are critical tools if you are building a motor. Too little torque and you get leaks and burn out bearings. Too much torque, and the motor breaks. If you are only torquing values less than 25 FT/LBs, then a quality wrench can cost less than $100. Any wrench up to 100# is going to cost you a decent amount of money, and you should spend it.
Buy it once, take darn good care of it, use it properly. Lasts a lifetime.
« Reply #6 on: February 05, 2016, 04:23:26 AM »
I used fish scale once to get the proper torgue  ;D - it was clumsy, but worked.
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #7 on: February 05, 2016, 04:55:12 AM »
I like, use, and own several different makes and sizes of torque wrenches. Sturtevant Richmont torque wrenches are my favorite for price, performance, and durability. They sell repair kits for the ratcheting mechanisms, they have interchangeable heads, and they are everywhere. I just did a search and on eBay alone, there are over 100 items listed. Put in "sturtevant richmont torque wrench" and you'll see.
I am a strong advocate for using torque wrenches where Plastic, Aluminum, Stressed Members, and Safety is concerned. I do folks say they don't need or use one, but I won't build or assemble without one. Getting those connecting rod caps to 14 (K) or 17 (F) lbs/feet is critical. Getting the nuts on my tire pressure monitoring sensors to 35 inch/lbs, my windshield brackets on my ST1300 to 30 inch/lbs, my fork caps to 14 ft/lbs - all are critical. I use them on my boat to torque the engine mounting bolts to 55 lbs/feet - the perfect torque to prevent cracked fiberglass and gelcoat and exactly what the manufacturer recommends to ensure proper attachment.
Two things to remember once you have your wrenches -
All torque wrenches are best/most accurate in their "sweet spot" range - the middle. I prefer to have at least 2 - one for 10~75 lbs/feet and one for 50~150 lbs feet. I also have one for 5~50 inch/lbs that I'll use in delicate applications where electronics or windshield plastics are being installed.
If you buy the "click-torque" type (my favorites), there will be a handle that you tighten to adjust the preload. Do Not leave that preload on after use. Always remember to loosen the preset back to zero so you don't leave the spring under tension.
One last observation, I do like the torque-click type wrenches the best. My one and only digital screen got broken when I dropped it and was a pain to see in bright and bad light so those are on my "no" list. The beam type are ok if you have room to fit your head directly over the beam/numbers to read the scale each time. 90% of my bolts/nuts are where I can't and don't want to fit my head, so that is why I like the click-torque type. Just a little practice and you'll both feel and hear when the torque is reached.
Best Regards, Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
« Reply #8 on: February 05, 2016, 06:41:22 AM »
+1
I have an inch lb up to 250, and ftlb up to 150
Offline ChopSticks
« Reply #9 on: February 05, 2016, 07:14:31 AM »
is there anyway to test that your torque wrench is still accurate?
Offline calj737
  • I refuse...
« Reply #10 on: February 05, 2016, 07:26:51 AM »
A simple means is to clamp a vise grip to the drive, then lever a known dumbbell weight or other known mass. Its not 100% accurate, but for pretty darn close, it works.
« Reply #11 on: February 05, 2016, 07:30:36 AM »
you can buy a torque wrench tester.
Fastenal offers this as a paid service.
Offline ChopSticks
« Reply #12 on: February 05, 2016, 07:51:42 AM »
but would I eventually need something to test my tester?  ;)
what if I have another torque wrench? could I say torque something down at 10lbs then mark it with a dot of paint or something, then use the other wrench at the same 10lbs and see if the mark moved?
also anyone try these?
http://www.amazon.com/ACDelco-ARM602-4-Measurement-Adapter-4-147-6/dp/B004VYURT0/ref=sr_1_1?ie=UTF8&qid=1454687313&sr=8-1&keywords=torque+wrench+tester
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #13 on: February 05, 2016, 08:19:43 AM »
I'll second that! At work we have to calibrate our torque wrenches so i tested two that I bought at HF and they were both pretty much spot on.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #14 on: February 05, 2016, 08:21:09 AM »
If its a fisherman's scale you know it's off by a few pounds and a few inches!  ;D
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
« Reply #15 on: February 05, 2016, 08:33:14 AM »
You mean something like this?
Offline Powderman
« Reply #16 on: February 05, 2016, 08:53:47 AM »
If the second wrench moves the fastener which wrench is wrong?
Offline wowbagger
  • Not much of an
« Reply #17 on: February 05, 2016, 08:55:43 AM »
Yup, I always default to cheap Harbor Freight tools to start with. If they break then I know I use that one enough to justify investing in a professional grade tool.
« Reply #18 on: February 05, 2016, 09:10:53 AM »
If was your money maker, then yeah, you might use a torque wrench enough to get it out of tolerances.
I think you'd have to build bikes in the double digits before a torque wrench would need calibration/adjustments.
Offline Sockeye
« Reply #19 on: February 05, 2016, 01:20:19 PM »
Thanks everyone, as I know your not someone paid to increase the review rating on amazon!
I think I might go with kobalt because it seems that it would be more prosumer, and I'd get more life out of it. I do plan to buy 2, one that is inch-lbs and another w/ foot-lbs. Harbor Freight does seem tempting but I only like to buy fool proof things from there and in the long run id feel like it would fail or go out of calibration.
What would be the max i'd need in the foot-lbs?
'76 CB750F
'97 VF750C
Offline ChopSticks
« Reply #20 on: February 05, 2016, 01:30:32 PM »
that's good to know, was just concerned how often these things ship out of calibration. I know the tekton ones amazon sells +/- 4% accuracy
Offline millla03
« Reply #21 on: February 05, 2016, 03:50:09 PM »
Another option I haven't seen mentioned is CDI brand. I have a 3/8" that covers most needs for these bikes. It's advertised as a "Snap-On brand", whatever that means. No plastic except for the case it came in. I consider it a middle of the road option. Not terribly cheap, but still half what a Snap-On or MAC costs and is a good quality tool that works as well as when I bought it a couple years ago.
I also have a Craftsman 1/2" torque wrench and the CDI is much higher quality. In hindsight, I would've gone with a CDI in place of it.
I've also read the article talking about the Harbor Freight wrenches, but I'm still leery of them. That store is my go-to for things like jack stands or other stuff that doesn't need to be accurate. Torque wrenches are worth spending more on, in my opinion.
Luke
72 Honda CB750 K2
78 BMW R100/7
83 Honda Nighthawk 650
07 Honda Rebel 250
Offline heyitsrama
« Reply #22 on: February 06, 2016, 02:13:36 AM »
my uncle left one of these hazets at my house..... its got much better feedback throughout the torque setting. My pops always says to reset (back to 0) after using it to ensure that it does not wear out... not sure how much truth there is to that
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Offline calj737
  • I refuse...
« Reply #23 on: February 06, 2016, 02:45:15 AM »
A fair bit. The internal spring is under pressure when the torque meter is set, and when in use. De-compressing the spring prolongs its life as well as promotes a longer, more accurate compression when under tension.
Offline Restoration Fan
  • My wife will never call me
« Reply #24 on: February 06, 2016, 05:24:21 AM »
I had a cheap Harbor Freight torque wrench.  Right up until Logan broke a bolt off a case bolt using it and it had never clicked.
I went and bought a Snap-On and have used that since.
I did set up a small test and set up a test at 12, 15, and 20 foot pounds using both wrenches (using the Snap-On as the 'correct' value).  The HF one was off by a little at 12, a little more at 15 and a fair amount at 20.  I don't remember exactly how much it was off because I just threw the thing away once I realized how far off it was.
Take it FWIW but I'll stick with the Snap-On.
