Author Topic: Let's talk torque wrenchs  (Read 7290 times)
Offline mystic_1
  • 1970 CB750K
Re: Let's talk torque wrenchs
« Reply #25 on: February 06, 2016, 06:59:25 AM »
BTW, the "right" way to check a torque wrench for calibration involves hanging very precise weights off of a calibrated wheel like one of these:
These setups are however prohibitively expensive.  Often companies will send in a digital torque transducer and have that calibrated to NIST standards and then use that as a reference standard to check calibration of their in-house tools.
In a DIY scenario you can do things like clamp the drive of the wrench in a vise and then hang known weights off the handle at a predetermined distance and then see if the wrench clicks.  Working out the weights and distances is pretty straight forward, torque is an expression of weight and distance, so 10 ft lbs is 10 pounds at a distance of 12 inches, or 20 lbs at a distance of 6 inches (120 inch pounds), or 5 pounds at a distance of 24 inches (again 120 inch pounds).
You can check against other wrenches but then you'll need at least two other wrenches and with luck at least two will match, otherwise there's no way to know which one is the accurate one.
What ever method you use, it's important to check the wrench at several points within it's range of operation.
Your best bet to be absolutely sure is to send it in to a place that'll check it on a rig like the one below.  This particular wrench was off by about 3% near the top of its range, but the deviation was linear and repeatable, so the wrench would still be usable so long as one corrected for this when setting torque.
mystic_1
- John Augustus Shedd
Offline Sockeye
« Reply #26 on: February 07, 2016, 08:09:22 PM »
Another option I haven't seen mentioned is CDI brand. I have a 3/8" that covers most needs for these bikes. It's advertised as a "Snap-On brand", whatever that means. No plastic except for the case it came in. I consider it a middle of the road option. Not terribly cheap, but still half what a Snap-On or MAC costs and is a good quality tool that works as well as when I bought it a couple years ago.
Ok, so I've decided to go with a CDI 2502MRPH 3/8-Inch Drive 30 to 250-Inch-Pounds for my low end needs and a Harbor Freight 1/2" 20-150 ft/lbs for the top end. Eventually I plan to replace the HF with a CDI equivalent.
I'm sure the HF will serve its purpose and pay for itself the few times I'll require it, plus it will leave me with a beater/loaner tool for the odd/misc jobs that pop up.
For this first year I'm only going to work on getting the bike road worthy, then I'll tear into everything next year.
'76 CB750F
'97 VF750C
« Reply #27 on: February 08, 2016, 03:21:48 AM »
I have found that I almost always need to borrow my bud's 1/4" drive 5-200(somewhere around there) inch pound wrench for these bikes.  The 1/4 drive is much more useful for getting at these little engine's hard to get at stuff, and torque values are relatively low...these are not tractor engines.
