Author Topic: CB650 Regulator/Rectifier work on 72 CB750?  (Read 1034 times)
Offline treetrimmer
  • 72 CB750 Hot Rod Styled
« on: November 08, 2006, 05:27:57 PM »
Hi,
Customizing my 72 CB750 this winter and have a question. I parted out a 1980 CB650 a while back but kept the combination regulator/rectifier. Can I adapt this to work on a 72 CB750? Not too worried about wiring as I am going to build a harness. Does anyone have a wiring digram for the conversion? ::)
Thanks for the help,
Jeff
More Honda Fun All The Time!
Offline oldfart
    • The Motorcycle Project
Re: CB650 Regulator/Rectifier work on 72 CB750?
« Reply #1 on: November 08, 2006, 06:13:14 PM »
It can be done.  Both bikes have electromagnet alternators.  However, the wire colors won't match, because on old vibrating point type regulators like the old 750's, the regulator is wired on the power side of the alternator's field coil, while on electronic regulated systems like the 650's, the regulator is wired on the negative side of the alternator's field coil.  I can help you with the color mismatch if you are interested.   :)
Mike Nixon
Why is there never enough time to do it right, but always enough time to do it over?
www.motorcycleproject.com
Offline treetrimmer
« Reply #2 on: November 09, 2006, 08:42:07 AM »
Oldfart,
That would be outstanding! Thanks for your help.
Jeff ;D
Offline blizzyb
« Reply #3 on: September 29, 2011, 01:18:03 PM »
How did this turn out?
