Author Topic: -Project Suzzie-  (Read 71788 times)
0 Members and 7 Guests are viewing this topic.
Re: -Project Suzzie-
« Reply #550 on: May 05, 2017, 01:39:59 PM »
You sell the Duc?
looks great!  Glad she's a fun ride...enjoy it before it gets really hot...was 100 on Thursday in Tucson, or was that Wed a friend was telling me...early hot weather everywhere, but not here today...barely going to see 57-58f
David
« Reply #551 on: May 05, 2017, 02:33:21 PM »
Looks great John!  Good to hear you had it out, I bet it was a thrill...
Offline toytuff
  • "watching the pinheads"
« Reply #552 on: May 07, 2017, 05:01:43 AM »
Thank you Steve. Yup, it's a kick alright. Barrel of monkeys. Always did like smaller displacement motorcycles.
I need to hook an external tachometer and compare to the one on the bike. It sweeps just fine but not sure how accurate it really is. Don't want a Big Bang Part Two on this one.  ;)
Offline toytuff
« Reply #553 on: May 07, 2017, 05:16:22 AM »
I wanted to install the factory trim around the windshield but it wasn't fitting tight. I was going to use adhesive silicone but figured it would squish out and make a mess.
How can I squeeze this together? It's rubber over metal. Hmmm. I looked up on the peg board above my desk and the light came on.
I set the width of the vise grip just a little smaller than the width of the moulding working it a little at a time until it was tight on the screen.
Much better now. Gives the screen a finished look and pulls the eye away from just a plain edge. Me like.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #554 on: May 07, 2017, 05:57:25 AM »
Great technique John!
I have a motorcycle problem.
Offline toytuff
« Reply #555 on: May 07, 2017, 06:35:59 AM »
Yankee ingenuity!
Looks way better. Notice the expensive catalog?
« Last Edit: May 07, 2017, 06:41:29 AM by toytuff »
Offline toytuff
« Reply #556 on: May 09, 2017, 04:59:03 AM »
Ducati picked up by new owner yesterday. Very nice lady, going to good home.
« Reply #557 on: May 09, 2017, 06:58:45 AM »
Nice? She looks hot!  Coincidentally, the last 550 I sold went to a female, she was "nice" as well....
Offline toytuff
« Reply #558 on: May 09, 2017, 04:43:28 PM »
She will look even better on the Ducati.  ;)
Offline toytuff
« Reply #559 on: May 19, 2017, 04:30:48 AM »
Just a follow up. Tachometer works just fine, riding it everyday. Fuel gauge works as the level finally came down. Speedometer cleared up sitting out in the sun.
I have to do math when riding but have it somewhat memorized now since it's in kilometers.
Speed divided by half plus tenth digit. (60k divided  by 2 = 30 plus 6 = 36 mph)
Ordered up side cover decals and will attempt to get those on correctly. Will have to go by older pictures of the bike. Looking at web pictures Suzuki seemed to put them all over the place. Canadian models were different then Euro models.
Doing a little research on the TSCC motor. When it hits 7K up to 9K the extra power is amazing for a 400cc motorcycle.
« Last Edit: May 19, 2017, 04:39:38 AM by toytuff »
Offline grcamna2
« Reply #560 on: May 19, 2017, 02:50:21 PM »
That's a powerful little 400,is it smooth running also ?
Offline toytuff
« Reply #561 on: May 19, 2017, 05:14:34 PM »
Yes, I was quite surprised myself. I think they were rated @44 hp. It likes 4K or above. I notice just a tad of vibration in the bars @ 4500 in 6 the gear, but other than that none. It likes 100LL gasoline also.  :D
Still getting the feel of it. Seems to "follow" the groves in the road but I did go to radial Avons which are just a little under the OEM bias size. Experimenting with tire pressure and running 35 F/R now. Maybe to much?
It's a hoot to ride but an in town bike. Can't see doing a long highway trip on it. Wouldn't have the time anyway. Suzuki geared this bike low and don't foresee changing the gearing. Just going to keep it and ride it.  ;)
« Last Edit: May 19, 2017, 05:17:51 PM by toytuff »
Offline grcamna2
« Reply #562 on: May 19, 2017, 09:25:32 PM »
The light bikes tend to track into the grooves,tire style can contribute.. I usually move around on rain grooves rather than letting them dictate how I roll over them.
Offline toytuff
« Reply #563 on: May 20, 2017, 04:36:47 AM »
Agree. Dry weight is listed at 386 pounds. Add 4.2 gallons of fuel and 3.2 quarts of oil to that figure.
« Last Edit: May 20, 2017, 04:39:22 AM by toytuff »
« Reply #564 on: May 20, 2017, 05:52:26 AM »
Good to hear your riding it, John.    The mid size bikes are fun.    35 lbs is not too much, I run some tires up to 40.
Offline toytuff
« Reply #565 on: May 20, 2017, 06:35:16 AM »
Oh yeah! Weather has been cool but about to end.
Doing some more reading and it appears in March of 2016 I ordered the wrong size tires. The rear needs to go on the front and a larger tire on the rear. Service book says to remove exhaust which I prefer not to do. I think I can do it with extra hands.
Front is 90/90/18, rear is 100/90/18. Should be front 100/90/18, rear 110/90/18.
Stock size in bias was  360/18 front, 410/18 rear. Just put the rear on the front and order new rear.
Have time to ponder the procedure as I won't do until next fall. Just going to ride it.  ;)
« Reply #566 on: May 20, 2017, 07:14:17 AM »
I've seen that in manuals too, certainly easier to remove the wheel with exhaust off, but much more work.
As long as you can get the axle out, shouldn't be an issue
What tires did you buy? Need a new front tire for my new Suzi...
Offline toytuff
« Reply #567 on: May 20, 2017, 08:15:30 AM »
Originally I bought these. 90/90/18 front, should be a 100/90/18 which is on the back. About a 1/2 inch from what I figure.
http://www.americanmototire.com/catalog/product_info.php?cPath=33_61_75&products_id=461
Rear should be 110/90/18, about 3/4 inch. Smaller tires on both ends. They are bi directional.
The swing arm is open at the rear so "it" might be possible to slide it all out. If not, bigger project.
« Reply #568 on: May 20, 2017, 09:53:31 AM »
As much as I like the Roadriders (have 'em on my Z1) want more on a vintage tread.
The open swingarm should make the rear wheel removable....
Offline toytuff
« Reply #569 on: May 20, 2017, 11:11:49 AM »
I found some old pictures from March 2016 when I cleaned the wheels. I went with the size that was on it when ordering a new set. 300/18 front, 350/18 rear IRC gs11. Cross reference to radial and I'm correct in size.
Seems different  web pages have different tire sizes. I'll stick with what I have and ponder next fall.
« Last Edit: May 20, 2017, 11:13:49 AM by toytuff »
Offline grcamna2
« Reply #570 on: May 20, 2017, 07:59:40 PM »
She'll look good in full leathers on that Duc  8)
Offline toytuff
« Reply #571 on: May 22, 2017, 04:06:18 AM »
Steve, have you checked out Heidenau tires? Many sizing options with vintage look.There is a great tire chart in PDF format worth downloading for reference.
My next set will be the bias tires. Radials are not to my likening on this motorcycle. Although the sizing is correct it's the rim width that is wrong for the tire. According to the GS forums this will get better as the tire wears in the center.
The IRC GS11 tires would of been a better choice. Will see how it goes when the mileage increases. Not a big issue given the riding I now do.
« Last Edit: May 22, 2017, 04:18:17 AM by toytuff »
« Reply #572 on: May 22, 2017, 06:25:27 AM »
Have not checked Heidenau tires, didnt think they were available in the U.S?
I do like the look of this one:
https://www.revzilla.com/motorcycle/heidenau-tires-k36
I like IRC, good budget tire.  I really like Continental, just bought em for my H2, but was surprised and disappointed they are no longer manufactured in Germany.
Offline grcamna2
« Reply #573 on: May 22, 2017, 10:35:13 AM »
I am enjoying long mileage on my ContiGo tire,they're still a well made tire.
Offline toytuff
« Reply #574 on: May 23, 2017, 04:31:03 AM »
Problem today is sizing. It might have been you that asked if I was going with the stock bias tires when starting this project. I went with radials.
The sizing is correct but with a narrow rim the tire is somewhat pinched. It gives a wobble effect on some surfaces. The GS forum says the handling will improve as the tire wears in the center. Width of rim is frt 1.60 rear 1.80. It also appears German models had larger tires than Canadian models. Can't verify but tire size is different depending where you look. A few GS forum members have laced 2.15 width rims.
It's not a safety issue otherwise they would come off. Just a weird feeling at lower speeds.
