Support the site. Your contributions keep this site running.
There are at least three variations on the CB750 final drive shaft. The differences are in the outboard bearing, and the auto-chain-oiling mechanism.The new crankcase is machined to accept the later-style final drive shaft with the dual-row bearings, so I sourced the appropriate shaft and gears.The earliest final drive shaft had a single-row bearing, with a notch for a half-circle locating ring.The next iteration of the shaft had a single-row bearing with no notch, and used a full-circle locating ring outboard of the bearing.The third iteration of the shaft had the double-row bearing, no notch, using the same full-circle locating ring. In all three instances, the location of the outer surface of the bearing is unchanged. The third variation of the shaft moves the bearing inward to accommodate the additional width of the bearing. You can also see that in version 2, the shaft has been beefed up in between the bearing and the gear.As far as I can tell, the first two versions of the shaft should be completely interchangable. The third variation of the shaft is different and cannot be used with the single-row bearing setup. The shaft required depends on how the crankcase has been machined.
