Author Topic: Cycle X 849cc Tin Coated Pistons  (Read 1206 times)
Offline stikman
  • Bit of an
« on: February 11, 2016, 01:22:48 am »
I couldn't seem to find much info on guys using the 849 Cycle X pistons.  Is there a reason they are 65.5mm instead of 65mm?  Are there any issues with the tin coating on them?  Those who have used these pistons, have you had generally good or bad results?
Any thoughts would be appreciated.  Cheers!
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: Cycle X 849cc Tin Coated Pistons
« Reply #1 on: February 11, 2016, 04:59:42 am »
65mm = 836cc, no?  65.5mm = 849cc?  i have run a set since long before they started using any type of coating. any questions in particular?  i have literally beat the piss outta the motor, and had no issues.  i have a new set still in the box.  you need some???
Offline cbr954
« Reply #2 on: February 11, 2016, 06:09:03 am »
They are bigger so you can use them with worn out 836 bore.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline Mitchell
« Reply #3 on: February 11, 2016, 02:42:30 pm »
What head gasket did you use for the 65.5 pistons?
Offline stikman
  • Bit of an
« Reply #4 on: February 11, 2016, 09:09:57 pm »
Ahh right.  Posted this late, dunno what I was thinking.
Wondered this too.  Will the cruzinimage 65mm head gasket work with these?
Offline Garage_guy_chris
« Reply #5 on: February 11, 2016, 09:34:40 pm »
I just measured my spare Cruzinimage headgasket and the fire rings measure at 67.15 mm un-compressed so i would say your likely fine with one.
I have seen these kits dirt cheap they come up on ebay for $99 from time to time
http://www.ebay.com/itm/Honda-CB750-SOHC-Big-Bore-Kit-New-CR-Cafe-Chopper-Bobber-Rat-Brat-/222014189330?hash=item33b113af12:g:Fp0AAOSwuYVWn9jo&vxp=mtr
Who has succesfully run these on the stock sleeves? Some people say the liners get too thin at 65.5mm
Offline stikman
  • Bit of an
« Reply #6 on: February 12, 2016, 12:48:02 am »
Thanks for checking those measurements.  Yeah, I was looking at that set and thinking of picking them up.
