Author Topic: ARD On CB550? Differences?  (Read 4065 times)
Offline jaguar
« on: February 11, 2016, 08:52:55 AM »
I just came across an ARD set up and some of the parts that came with it seem to be more CB550 then CB750.
At one point I wanted to run a magneto on my chopper, and bought an adaptor plate that I was told was removed from a CB550.  Only got that plate, nothing else.  Actually I have never seen a CB550 with an ARD.
Can see that the plate is drilled for the CB550.
Top is a CB750 unit.  For the lack of a better way of describing it, the mounting holes are mirror image of each other.
You can see that the drive post is smaller, and the bearing is smaller too.
BUT things did not bolt up.  Can see that the magneto head doesn't fit with the carbs.  Maybe a different arm was used on CB550 applications?
Offline jaguar
Re: ARD On CB550? Differences?
« Reply #1 on: February 11, 2016, 08:58:25 AM »
Mainly the question came up because I just bought this CHEAP on ebay.
I had a spare magneto head so figured I would build up another unit.
The bearing had seized and opened up the hole.
But I noticed that it used the smaller of the two bearings I had ever seen.
And that it seemed to have the 550 pattern drilled in the adaptor plate.
It is mounted to the bracket in such a way that I assume it was most recently used on a CB750, but the plate is drilled for a 550 (they just didn't mount everything 100%)
Anyone have any incite?
« Reply #2 on: February 11, 2016, 11:32:31 AM »
Is there maybe a difference in mag center to crank center distance, meaning. Also a different belt length..?
Offline jaguar
« Reply #3 on: February 11, 2016, 12:35:31 PM »
I have not seen a difference.
Offline BPellerine
« Reply #4 on: February 11, 2016, 02:25:31 PM »
there is a pic in the inspiration thread,or sohc on the road of a 550 with an ard on it,think it is also turbo.bill
1978 CB 750K ard and webers
another anfob
Offline jaguar
« Reply #5 on: February 11, 2016, 03:43:01 PM »
I have a posa set up for that cb550, maybe st will clear.
Offline BPellerine
« Reply #6 on: February 11, 2016, 05:55:22 PM »
page 404 inspiration thread.bill
another anfob
« Reply #7 on: February 11, 2016, 06:14:11 PM »
Any body remember the handle of that guy with the yellow turbo street tracker 550?  I feel like he has a Magneto on his.  Kind of a frequent poster in "Lets See Your SOHC out on the Road"...but maybe  not for several Months?
« Reply #8 on: February 11, 2016, 06:19:10 PM »
Bob 3050. ?_
« Reply #9 on: February 11, 2016, 06:46:20 PM »
I think thats him, Frank.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #10 on: February 12, 2016, 07:44:04 PM »
I have a pic of one on a 500/550 somewhere...I'll see if I can dig it up.
Glad to see something's being done with that plate Jag!
« Reply #11 on: February 12, 2016, 07:53:41 PM »
I know its 30-50, 30/50, or 3050....but not sure if his name is included.
Found him Bob3050.. He did not have a mag.. They would fit easier with the turbo.
« Last Edit: February 12, 2016, 08:10:31 PM by 754 »
Offline jaguar
« Reply #12 on: February 13, 2016, 05:00:45 PM »
Tried it once before.
But this last arm was a $30 deal on ebay so back at it.
Would be fun to have a magneto on each of my SOHCs.
Have lesters on both my CB750s already...lol
Offline jaguar
« Reply #13 on: February 14, 2016, 09:18:35 AM »
Okay, so time to tackle the magneto drive gear.
Every unit I have ever worked with had a 30 tooth gear on the magneto and a 15 tooth on the crank.
This makes perfect sense that they are 2:1.  I guess it doesnt matter how many teeth are on each gear, as long as they are 2:1.
The 30 tooth XL gear is super easy to fine.  Comes in steel or alloy and also has a few options for flanges.
So far there are not many options for bores.  I assume that there is not much need for it.
Tried to see if I could get lucky and find one that had a tapered bore to slide right onto the magneto, but no dice.
I have a couple of these gears to mess around with though.
The shaft on the magneto has a slight taper on it.  Dont know what it is yet, but should be easy to measure, or look up.  Normally the magnetos use a keyway to secure the gear to the shaft, but I have never seen the ARD units with this keyway.
So I need a way to get the two together.
What is the easiest way to machine a tapered bore into the shaft?  Lathe?  Special bit?
Would kind of like to use a keyway as an "improvement".  I can use the smaller gear (with less radius) to do any fine tuning.
Plan to have the 850 Commando buttoned up in a few more weeks.  After that I will flip a coil as to the next focus.
Either dig out the chopper motor, get it back together and  try and mount one of the magnetos to it, OR drag the Seeley back to the workshop and get another one of the magnetos set up on it.
Fun times.
Offline Greggo
  • Somebody's
« Reply #14 on: February 14, 2016, 09:30:50 AM »
Here's the pic I was thinking of...
Offline jaguar
« Reply #15 on: February 14, 2016, 09:33:45 AM »
If my memory is right, that was a custom install?
Like not a collection of bolt on parts?
Offline Greggo
  • Somebody's
« Reply #16 on: February 14, 2016, 09:43:41 AM »
More info here, and maybe the guy to track down: http://forums.sohc4.net/index.php/topic,14994.msg199389.html#msg199389
Offline jaguar
« Reply #17 on: February 14, 2016, 10:01:58 AM »
Will have to sit and read the thread again.
Lots of good info in there.
On a side note, if anyone needs parts or info on these things, I have a list of needed part numbers and a few sources for them.
Have also done the RC units too.
Have really enjoyed the research and learning about these old speed parts.
« Reply #18 on: February 14, 2016, 12:35:13 PM »
Taper is usually bored,but can be done with tapered reamer.. But keep in mind. The depth of taper is critical.
 On a lathe , the taper is made by tilting the crosslide..requires a lot of care setting up.
 If you hold the pulley (not a gear) for boring mount in such a manner that you can fit the shaft and cover to it, to check your offset..
  Dont tap it together as it will probably stick. You also need the taper shaft to check your fit of the taper, ie get the angle just right.
 When you find components such as he pulleys they usually have a small hole (used in the manufacturing process), then are modded to fit the application.
Offline jaguar
« Reply #19 on: February 14, 2016, 01:47:14 PM »
Sounds like a pain.
« Reply #20 on: February 14, 2016, 03:51:36 PM »
 it is a pain if you got to pay someone full nut to do it, that doesnt really care if they get the job..
Offline jaguar
« Reply #21 on: February 14, 2016, 04:10:49 PM »
Seems to be most machine shops these days.
They only want to do big production runs.
« Reply #22 on: February 14, 2016, 06:11:44 PM »
One-off parts cost more to make than production parts; it takes a lot of time for set-up for the first part, but it gets faster once a routine can be established.
Offline jaguar
« Reply #23 on: February 14, 2016, 06:47:16 PM »
I work in robotics and do some prototyping.
Do get production.
Issue I find is that so many small shops are just holding out for Ford to walk in the front door, they just kick everything else down the road.
Surprised some stay opened.
« Reply #24 on: February 14, 2016, 07:01:33 PM »
It may take one hour or more just to get the compound set at the correct angle, and a couple of hours more to grind a broach to cut the key-way, much less the actual machining time on the pulley. How much are you willing to pay?
If I had to pay shop rates for the custom parts I made for my bike, the bill would have run into the thousands of dollars. :o
