Author Topic: Some oil got on my header wrap...  (Read 3581 times)
Offline bookah
« on: February 15, 2016, 05:08:37 PM »
Hi everyone -
While changing oil & filter yesterday, some oil (around 1/4 cup) spilled from the filer housing and onto my wrapped 4into1 pipes. I rode it to work and of course it smoked a ton. Has this happened to any of you with wrapped pipes? It seems like this would be an incredibly common issue.
Is there an easy way to clean the oil off, or am I better off just unwrapping the pipes?
1978 cb550
Offline carnivorous chicken
Re: Some oil got on my header wrap...
« Reply #1 on: February 15, 2016, 05:14:45 PM »
just let it burn.
Offline bookah
« Reply #2 on: February 15, 2016, 05:17:03 PM »
just let it burn.
Yea, that's what I originally planned to do, but after a few rides it's still smoking quite a bit, and I'm a tad concerned about it actually catching fire - but I didn't want to get ahead of myself so I came here to ask.
1978 cb550
Offline hondachary
« Reply #3 on: February 15, 2016, 05:23:41 PM »
I once forgot to tighten the oil line fasteners and had a fair amount of oil drip onto a wrapped exhaust... Not my brightest moment. Let it burn...it will smoke a ton but it will eventually burn off.
Offline Powderman
« Reply #4 on: February 15, 2016, 07:34:30 PM »
Another advantage of header wrap on a bike.
Offline bookah
« Reply #5 on: February 15, 2016, 07:39:31 PM »
I put it on bc it adds 29hp and I heard it helps me lean better  ;D
1978 cb550
Offline calj737
  • I refuse...
« Reply #6 on: February 16, 2016, 02:33:58 AM »
Don't be fooled; it only adds 26BHP. But it does help you lean  ;D
You could try a a rag soaked in Dawn detergent applied by "blotting" the area to help cut some of the oil. Let that dry and maybe it will help reduce the smoking. I too imagine its a common issue, so better protection next time. I wonder if Kott or someone makes an exhaust condom for such maintenance tasks???  ::)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #7 on: February 16, 2016, 06:24:54 AM »
I bet Ichiban Moto would...
Also...
--Evan
1975 CB750K "Rhonda"
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
« Reply #8 on: February 18, 2016, 12:39:06 PM »
I don't think you could catch exhaust wrap on fire even if you tried really hard.
Just let it burn.
-David
Offline bochnak
    • How-To Motorcycle Repair Blog
« Reply #9 on: February 19, 2016, 11:27:02 AM »
Hot water mixed with Dawn in a spray bottle. Let soak and rinse well. Box fan to dry it off. You may have to repeat a few times. It will still smoke a bit after all of this though.
Offline koendd
« Reply #10 on: February 21, 2016, 10:06:46 AM »
had the same due to a leaking oil line, just let it burn, It'll go away in the end :)
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
