Author Topic: CB750 F to K  (Read 2918 times)
Offline GOONZ
CB750 F to K
« on: February 19, 2016, 11:59:42 AM »
It all started when I Payed way to much for a non running CB750F1 in September 2013.
I can't remember why, but I was dedicated to build myself a motorcycle with a 4 in line engine.
How I bought her
Couple of hours in my possession
Chop chop
Stripped the paint of the tank and fabricated somewhat of a seat
Pulled the motor. At first the idea was to only refresh the top end.
But after some reading I decided to to do the complete engine.
After soda blast
I wasn't a big fan of the F tank. Found this K tank for 30 euros!  ;D
My first idea was to hide the oil tank under the seat. Therefore I needed seat with some room
Then it was time to seat some valves
I didn't like how the seat looked and at the time I couldn't find enough info for building myself a oil tank.
So change of plans. This is where I concluded I liked the tracker look
Bought a loop, loop didn't fit. Apparently F frames are not as wide as others?
Bought myself a cheap MIG welder second hand and made the loop fit
Time to rebuild the motor! I did everything that needed to be done. New bearings, new stretchbolts, new chains, new tensioner,...
Made some new suspension mounts
I really hate the original welds, but I don't have the skill to re-do it all. It's also not necessary, I'll get over it  :)
Got a great deal on a GSXR front end!
Top triple mod for the handlebar clamps
Deglazed the jugs
The previous front end I scored came out to be from 1998. As I wasn't sure I was going to get that to work I opted for a 2005 fork
Ordered a Cognito Moto hub & stem for the conversion
Had some modern wheels made
Front Cognito Moto hub, rear stock F1 hub. I'm pretty sure a lot of people are not going to support my tire choice  ;D
First real mock up!
The time I tried to weld aluminium with steel on a MIG wilder  :o ::)
Rear sets
Worlds most simplest brackets
As much as I like Cognito Moto's stuff, shipping and taxes are heavy. Waaaay heavy!
So I tried to fabricate my own tank
Made a couple of mistakes. Started with hot rolled steel. Cold rolled steel seems to be the standard for oil tanks.
I cannot figure out if the inside needs to be coated to prevent rust. Maybe the oil takes care of that?
I followed a fellow DDT'er his measurements. It stated a 3,2qt capacity. After building the thing it only fits 2qt's  :o
Back to the drawing table with it.
I have been reading a lot about POD filters. I know, I know..
Tried the stock filter today, I just don't like the look.
That's it for now. I'll try to update regularly! Lot's of things on my to do list!
« Last Edit: February 20, 2016, 04:44:49 AM by GOONZ »
Re: CB750 F to K
« Reply #1 on: February 19, 2016, 12:39:55 PM »
you had a busy day  ;) ;D
Offline GOONZ
Re: CB750 F to K
« Reply #2 on: February 19, 2016, 12:47:06 PM »
Haha, it's over a time span of 2 years  ;D
Offline beemerbum
Re: CB750 F to K
« Reply #3 on: February 19, 2016, 12:49:08 PM »
Saw this bike near my house. Beautiful oil tank fabrication. Wish it were mine. Looks like what you are after.
Offline GOONZ
Re: CB750 F to K
« Reply #4 on: February 19, 2016, 12:54:43 PM »
That is indeed what I'm after! Thanks!
Re: CB750 F to K
« Reply #5 on: February 19, 2016, 01:20:38 PM »
Sweet build, Goonz!
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: CB750 F to K
« Reply #6 on: February 19, 2016, 03:20:40 PM »
It was a pretty nice complete bike to begin with  :)
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Mantree
Re: CB750 F to K
« Reply #7 on: February 19, 2016, 11:01:29 PM »
I love the split tail lights in looking online for a set right now to rebuild my tail light as the turn signal is dim on mine
And I personally like pods for how open it makes it
Sent from my ME302KL using Tapatalk
« Last Edit: February 20, 2016, 08:59:25 PM by Mantree »
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: CB750 F to K
« Reply #8 on: February 20, 2016, 01:58:26 AM »
Thanks for posting, very inspirational and after the sh1t weather we've had, makes me want to get out and do something! Well done for showing the stuff that didn't go right first time too, wouldn't want the newbies to think it's simple ;D
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline GOONZ
Re: CB750 F to K
« Reply #9 on: February 28, 2016, 09:07:04 AM »
Got some stuff this past week so time for a update!
Ordered some fancy titanium rotor bolts:
Shoulders are to long
Fixed it with some washers. Not sure if I'm going to keep it this way. The seller couldn't give me an answer if this was safe or not.
Some goodies:
Headlight bracket fabrication:
Left some room for the acewell gauge
Rotors and calipers installed
The only switch I will be running on the handlebars. They are from a company called Motone and are smaller then the Motogadget ones.
I messed up with my previous handlebar clamps. Got some new ones, but I'm not happy with the height. They need to come down a couple of millimeters
For the coming week I'm building a bracket for the rear master cylinder
Offline Mantree
Re: CB750 F to K
« Reply #10 on: February 28, 2016, 03:35:12 PM »
Are you not running a horn?
Sent from my SM-G900V using Tapatalk
Offline GOONZ
Re: CB750 F to K
« Reply #11 on: February 28, 2016, 03:44:22 PM »
I will be only running the obligated stuff according to the laws of my country.
Lights and a horn. That's it  ;D
Offline GOONZ
Re: CB750 F to K
« Reply #12 on: March 27, 2016, 09:03:58 AM »
Got some updates:
Battery box
Seat pan
Kick stand mount
Re-did the oil tank. Ran out of co2 for my welder. Just had enough to tack everything
75€ worth of fittings  ??? ???
Spend some time on the seat. No happy with it , yet.
I also started on a custom loom. Waiting for the speedo to come in so I can finish it.
Not sure what I'm going to to with the exhaust. What you see on the picture is a mock up. I'm not even sure if it's possible this way. I have 0 knowledge of exhausts.
Really close to powder coating and upholstery!
Re: CB750 F to K
« Reply #13 on: March 27, 2016, 09:08:07 AM »
Looking good but I would be concerned about the exhaust being so low if you are to ride on the street.
