Author Topic: Bimota HB1 Clone build  (Read 68084 times)
Re: Bimota HB1 Clone build
« Reply #50 on: February 26, 2016, 03:02:06 PM »
That sounded seriously kinky Brent, who's yer Daddy.... ;D ;)
FTFY
Thank you Sir... ;D   Thats what I was hearing ... ;)
Offline Artracing
« Reply #51 on: February 26, 2016, 03:17:48 PM »
I was originally going with Ceriani style Triple Clamps, but needed a wider set, because of the Brembo calipers needed more room.
So I machined these up, but added the adjustable offset bushing. 45mm Offset with 2.5mm and 5mm offset bushing for 40-50mm range.
So are you machining spacers for the hub to calipers to accommodate for the wider fork spacing?
Yes, I modified the hub and then added spacers. I do sell spacers. Any size up  3/8 thick of  $30 each
Offline Artracing
« Reply #52 on: February 26, 2016, 03:28:07 PM »
Engine is going together now. Top to bottom. Nothing special. Just mild cam, oil pressure gauge, electronic ignition and solid state regulator.
Offline sbeckman7
  • Glutton For Punishment And/Or
  • Slow and steady
« Reply #53 on: February 26, 2016, 07:37:32 PM »
Engine looks sweet.  Question: Why is redline at 8k?
Offline Artracing
« Reply #54 on: February 27, 2016, 03:58:32 AM »
I did it as a range to be in. Going beyond the red voids the warranty. ;D
Since I had the dial custom made,  I can make it anything you want, if you buy the bike.
BTW, if you want the red range at 12 o'clock position, just loosen the outer ring and rotate the tach.
Offline Artracing
« Reply #55 on: March 16, 2016, 01:28:00 PM »
Here are the spec's on the bike.
Honda CB750 Engine 100% Rebuilt and detailed
Engine CB750 K4 1974
Megacycle Cam
K&N Air Filter
Custom Oil Pressure Gauge by Rob
Dynatek Electronic Ignition
Solid State voltage regulator and rectifier
4X4 Custom Exhaust with hand bent megaphone silencers
Frame:
Custom HB1 stressed-member frame by FrameCrafters
HB1 Carbon Fiber tank
Carbon Fiber seat with leather upholstery
Carbon Fiber front fender
Paint and decals as original
Suspension:
Brembo Caliper
Dual front disc brakes with modified hub
Drilled rotors by Rob
Brembo Caliper  - rear disc brakes
Fully tuneable Ceriani GP35R forks
Custom adjustable offset triple tree, 45mm +/- 2.5mm or +/- 5mm by Rob
Tommaselli Clip-Ons
Tarozzi rear sets
Excel Aluminum shoulder rim
Stainless Steel spokes
Bridgestone BT45 tires
Custom Grips
Electrical
MotoGadget M-Unit  with Custom wiring
•Micro Processor operated supervised circuits
•Hazard warning lights
•Internal fusing with current monitoring with automatic circuit shut down
•Semiconductor switching
•Automatic turn signal shut-off
•Programmable flasher Digital brake light modulator with flashing sequence
•Integrated Starter relay Automatic headlight turn off during starter routine
•Integrated horn relay
•Integrated alarm system
•LED circuit indicators for active circuits
Ceriani headlight mount
CB750 headlight with Halogen Tri-Bar lamp
CB750 Handle bar controls
CB750F Front brake master cylinder with customized cap.
CB750 Tachometer with custom Bimota HB1 dial
Dakota Digital Speedometer
Custom Dashboard and indicators by Rob
Anti-Gravity lithium battery
« Reply #56 on: March 16, 2016, 03:48:42 PM »
Just add money and stir.... ;D
« Reply #57 on: March 16, 2016, 04:27:52 PM »
Oh that cannot be too bad.  He didn't go off the deep end with engine performance upgrades.
« Reply #58 on: March 16, 2016, 05:37:47 PM »
There's a deep end...?    ;)
« Reply #59 on: March 16, 2016, 06:40:25 PM »
Quick threadjack:
Visited my buddy Paul last Sat, he wanted to see my GPz, so I rode that over.
While there I took a few minutes to see his YB6, which has a Yamaha 989cc, 140hp Bimoto. There were only about 550 of these made, his is mint with only 475 miles, it's in his living room!  He also has the Bimoto book which looks to be a great reference book.
He obviously has the seat and bodywork off, but I'm riding this thing once it's back on the road!
« Reply #60 on: March 16, 2016, 07:10:17 PM »
That book is all kinds of cool.
Offline Artracing
« Reply #61 on: March 17, 2016, 04:23:44 AM »
Quick threadjack:
What is in the book relative to HB1, accept for that diagram.
Online calj737
  • I refuse...
« Reply #62 on: March 17, 2016, 04:33:25 AM »
Looking at the diagram Stev-O posted, I'd be curious about steering lock issues with the way the frame front tubes pass outside the upper upper rails. Surely Bimota dealt with this, but in real life, I'd love to see that frame and triple setup and see how much rotation lock-to-lock there is.
Offline Artracing
« Reply #63 on: March 17, 2016, 10:42:55 AM »
The triple tree will be stopped by the upper forward frame.
« Reply #64 on: March 18, 2016, 04:06:44 AM »
Quick threadjack:
HB1 in different trim, history, factory parts lists, etc. I bought 2 of them years ago and gave one to a friend for his birthday. I found them in what was basically a bargain bin.
Offline Artracing
« Reply #65 on: March 18, 2016, 05:06:55 AM »
Quick threadjack:
OH wow,
Any chance I can pay you for copies of those pages.
Rob
« Last Edit: March 18, 2016, 11:08:03 AM by Artracing »
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
« Reply #66 on: March 18, 2016, 10:46:23 AM »
Uh, subscribed
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Offline Artracing
« Reply #67 on: March 18, 2016, 11:10:03 AM »
Bottom End complete
Online calj737
  • I refuse...
« Reply #68 on: March 22, 2016, 04:56:43 AM »
That's an interesting point. I wonder what the original HB1 entailed with respect to engine modifications? For the depth of this "recreation", I would think an 836 Wiseco kit would have been installed to produce better performance consistent with Bimota heritage. It would be a shame to have a bike all dressed and "no way to go"...  ???
« Reply #69 on: March 22, 2016, 02:22:44 PM »
I know you are referring to the original one but, I'm not too sure any HB1's were sold with engines, they were essentially a frame and body kit, totally up to the buyer what engine specs you'd run.... I think the HB1 was built before Weisco started making piston kits for the 750, 900 and 970 {as Honda were using},  were popular for racing back then... ;)...
« Reply #70 on: March 22, 2016, 02:30:10 PM »
I know you are referring to the original one but, I'm not too sure any HB1's were sold with engines...
Incorrect there, Mick.  Actually Bimoto manufactured engines later on but had major issues:
"The V Due, introduced in 1997, had a design flaw with its engine. Bimota was forced to ditch the novel fuel injection system and re-engineer the entire engine. Bimota ultimately recalled the entire run of the motorcycle. While this was occurring, during the 2000 World Superbike season, one of Bimota's main sponsors disappeared, owing the company a great deal of money. The combination of events forced Bimota to file for bankruptcy and close their doors."
« Reply #71 on: March 22, 2016, 02:35:14 PM »
I was only talking about the HB1 Steve. So back to being "correct".... ;D ;)  Any Bimota with the "B" in the middle of the model designation is equipped with another manufacturers engine, only the V-due bucked this trend..  I'll have another go, The First letter of the model designation of Any Bimota is a reference to the engine manufacturer, HB1, Honda Bimota 1st model, YB1 Yamaha Bimota 1st model,  KB1, Kawasaki Bimota 1st model and so on...
« Last Edit: March 22, 2016, 02:45:46 PM by Retro Rocket »
« Reply #72 on: March 22, 2016, 02:48:55 PM »
Damn, nice to know we have resident Bimota experts here!
Online calj737
  • I refuse...
« Reply #73 on: March 22, 2016, 02:55:37 PM »
I know the designation convention too, Mick, but I strongly suspect since all that were built were intended purely as a racebike, that the motor would have been "stock". They had Keihin 28's for Pete's Sake! The recipe Bimota has always integrated was a manufacturer's motor, tuned and turned up, plus a frame of their own design, and suspension of the highest quality available, plus their bodywork.
But I'll return to my prior premise: given the nature of this recreation, Wiseco 836 seems the minimum.
I'm not besmirching anyone, just making an observation. I think a hot street motor would be the Bee's Knees for this product.
« Reply #74 on: March 22, 2016, 04:01:33 PM »
Yeah, I understand why you are saying Cal, what I was saying is that most HB1's i've seen, all had different engine configurations, I've seen them with Jap auto 970/1000cc engines, 900cc kitted, 970 kitted, CR31 equipped, It was up to the buyer what was done with the engine, after buying the frame and body kit, Bimota didn't supply them with engines, there were 10 "kits" sold , I'm pretty sure that the only ones that were produced at Bimota that had engines in them were Bimota's actual race bikes, the ones that were sold to the racing public were just frame kits, No engine fitted... ;) .
The kit..
 1    frame, made of steel tubes (Columbus).
 2  swingarm box, steel.
 3  Ceriani fork (35mm).
 4  Front oil tank.
 5  four exhaust pipes.
 6  runways.
 7  petrol tank.
 8  fuel cap (Alu).
 9  Saddle-tail holder (GRP).
10  front rim (magnesium).
11  rear rim (magnesium).
12  Dual front disc brake (Fontana).
13  pump front brake system.
14  rear disc brake (Fontana).
15   shock absorbers (couple Ceriani or Marzocchi).
« Last Edit: March 22, 2016, 04:06:41 PM by Retro Rocket »
