Author Topic: 1975 Honda CB550F or K, which model is this?  (Read 1477 times)
Offline sitrinh87
« on: February 20, 2016, 05:07:37 PM »
Hi guys, I'm new to this forum and does not own a bike YET. I'm currently looking at a 1975 CB550 and I'm not sure if it's a K model of a F model. Can you guys help me figure out which model it is before purchasing. I'm attaching some pictures of the motorcycle below. The VIN# CB5501225780
Offline Scott S
Re: 1975 Honda CB550F or K, which model is this?
« Reply #1 on: February 20, 2016, 05:29:44 PM »
 Looks like a K.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline harisuluv
« Reply #2 on: February 20, 2016, 05:36:50 PM »
I just see the one picture..  It does look like a K but that's just based on the tank and side cover.  It could be a F and have a swapped K stuff.  If you want to know, you would have to ask the seller.  See what the Vin plate says, look up the serial numbers, for the engine and the frame, etc.
Offline sitrinh87
« Reply #3 on: February 20, 2016, 05:51:26 PM »
Thanks guys, I asked the owner but he doesn't know, he bought it from a shop that works on vintage bikes. I do have a picture of the title, but I try looking up the VIN and engine #, still doesn't let me know what it is  :o. I'm a newbie to motorcycles, I appreciate it if you guys can tell me what it is exactly or have any other guesses?
« Reply #4 on: February 20, 2016, 06:18:09 PM »
My money is on it's a K model.  The vin is the engine number, the bike may have come from WI, very common for them to use the engine number.
Ask the seller for the frame number, it is stamped on the left side of the neck or located on the tag on the R side of the neck.
« Reply #5 on: February 20, 2016, 06:57:28 PM »
those sidecovers will not fit the F frame or the 77k...so it is definitely a k.  If you want further evidence, post pictures of the brake side riders footpeg, kickstarter, and brake pedal, and the swingarm axle adjusters.  Also the vin number tag will confirm that nothing has been modified.
Offline goldarrow
  • one day, i'll be an
« Reply #6 on: February 20, 2016, 07:07:18 PM »
Looks like K
CB550 K0
Offline jonda500
« Reply #7 on: February 20, 2016, 10:25:11 PM »
I can see by the pillion peg subframe that it is definitely a 'K' model and by the frame number that it is a 'K1'.
John
A starter clutch thread:
Offline flatlander
« Reply #8 on: February 20, 2016, 11:51:34 PM »
yes, certainly k.
it's also got pods and an aftermarket exhaust. make sure you know how it runs before buying.
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
« Reply #9 on: February 21, 2016, 02:18:18 AM »
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=e1f3h38ab6b88u7oa47dn25f95&/topic,60973.0.html
« Reply #10 on: February 21, 2016, 06:20:40 AM »
no problem..   .both bikes is fine.and have only few diff parts...
.just test it. gear must thange problemless...both up i gear...and dovn gear shift(give often some problems)..on hard load..falce free gear...
.and thek the valve train for Wear...rattel in cam/valvets..is a common problem in erly 500/550
small oil leakes is no problem...most bikes leakes a bit..
.if idel is stabil..and it takes rpm fine..all good...pods often give some flat spots in acceleration..
i hate all this v-w.... vords
