Author Topic: change fork tube - no center stand  (Read 1166 times)
Offline a_mo
« on: February 22, 2016, 05:34:26 AM »
hi!
im turning a cb 750 into a cafe racer. now i have to change the tubes in the front fork. anybody has any good ideas how to do this without center stand, a good roof to lift the bike or anything else...
when i changed the top triple tree i layed the bike on the side - worked fine!  8)
i could do this again. but maybe it will damage the bike somehow?
what do you think - is it safe to lay the bike on the side for maybe two hours...
Honda CB 750 K6 – 1977
Offline Kenzo
Re: change fork tube - no center stand
« Reply #1 on: February 22, 2016, 07:47:41 AM »
Build a little "A" frame (like on a saw horse)...should fit between the steering neck and frame.
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
Offline thirstforspeed
« Reply #2 on: February 22, 2016, 07:56:47 AM »
i know this is using a center stand, but the idea is the same. pics taken off my blog. http://thirstforspeed.blogspot.ca
build a similar front frame
take off header
support bike on bolts for front engine mount
profit
« Reply #3 on: February 22, 2016, 08:31:22 AM »
I use a wide ratchet strap attached to the ceiling joists and hoist it up. Works great and is very safe.
« Reply #4 on: February 22, 2016, 11:14:35 AM »
Center stand NOT needed!
Offline a_mo
« Reply #5 on: February 22, 2016, 11:33:22 AM »
thanks! i found my new hero. im going to try this technique ->
« Reply #6 on: February 23, 2016, 03:10:23 AM »
Will not work with stock exhaust on a CB.
Offline a_mo
« Reply #7 on: February 23, 2016, 05:41:28 AM »
i know. ill remove them, and let it stand on the frame...!
