Author Topic: K0 500 Four Speedo Gear Box Fitting instructions Please  (Read 775 times)
Offline paulbaker1954
  • I 'll just be 5 minutes dear!!
« on: February 22, 2016, 08:12:42 AM »
Is this supposed to be fixed somehow so it cannot rotate.
I have reassembled my front wheel and can't work out if the speedo drive is supposed to have a lug or something to stop it rotating. Right now it will rotate about 20 degress in each direction and seems to hit some kind of stop.
The Honda service manual says
"Make sure that the speedometer gear box is mounted in the proper position."
But it sadly does not say how to achieve this
If you think there's light at the end of the tunnel it's usually another train !!
2014 Triumphy Trophy 1200
1971 Honda CB500 Four K0
Offline jonda500
Re: K0 500 Four Speedo Gear Box Fitting instructions Please
« Reply #1 on: February 22, 2016, 07:43:01 PM »
If the axle is done up tight, it should rotate freely only with the axle, but once the axle is clamped into the forks it should be held tight, John
A starter clutch thread:
« Reply #2 on: February 23, 2016, 12:18:14 AM »
Hi John
Still think I am confused.
The axle has a hole in one end right so if i stick a screwdriver in hole and tighten up nut on axle at other end to the point the gearbox is tight then axle seems to be locked up.
This is before installing in the forks of course.
I must ne missing soemthing really obvious here
Offline jonda500
« Reply #3 on: February 23, 2016, 04:36:29 AM »
Does your speedo gearbox turn ok when you remove it, poke a screwdriver in and use it to rotate the two lugs you can see under the seal? - it sounds like it may be seized
John
« Reply #4 on: February 23, 2016, 08:21:21 AM »
Thanks John
i will have a look at the week end when I get back on the project.
Offline jonda500
« Reply #5 on: February 23, 2016, 03:53:25 PM »
Also I'm thinking alternatively maybe your collar (that's under the chrome retaining ring) didn't engage properly with the two lugs(/tabs) in the speedo gearbox?
John
