Author Topic: Playing with a rear cowl design.  (Read 1432 times)
Offline Ravie
  • Definitely not a
  • Soul to Soul
« on: February 22, 2016, 05:14:09 pm »
The seat I bought for the bike has this little...tail on it. It's kinda ugly and it doesn't cover the rear hoop or the wires running from the tail lights. So I decided to play around and come up with a design to cover it all. Something easily detachable that covers the silly bits.
I wasn't sure how to terminate it at the front/bottom...so i just curved it there. I didn't want it to cover all of the leather on the back which is why that deep V is there...it matches the shape of the "tail" to some degree. I just didn't want a moisture trap underneath.
I figure I can get some aluminum and just shape this by hand. It was made from a single flat piece so it is just a matter of matching the radius and bending it.
Thoughts?
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Re: Playing with a rear cowl design.
« Reply #1 on: February 22, 2016, 05:38:14 pm »
 You might be able to leave a tab to bolt to the shock or turn signal mount. Just a thought, or a dzus button on each side, that would look racey.
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #2 on: February 22, 2016, 05:52:14 pm »
Yeah those little tabs you see sticking out are over the grab bar mount bolts. Don't think I'll go that route unless I can do some sort of stud with a chrome wingnut or something.
« Reply #3 on: February 22, 2016, 06:27:06 pm »
I like where you are trying to go with that.  Might look at some sport bikes that have removeable cowls...cowl on?  solo seat....cowl off? two up.  That open V on the top looks kinda goofy imo.
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #4 on: February 22, 2016, 06:31:22 pm »
I agree. I think it could easily just follow that top edge contour like the sides do and look much better. I suppose I could put some thin closed-cell foam there to keep moisture out.
Offline Davez134
« Reply #5 on: February 22, 2016, 07:39:02 pm »
I second this. The shape looks great, lose the V and go straight across. Good idea man, I like it
Offline ChopSticks
« Reply #6 on: February 22, 2016, 08:28:58 pm »
Love the idea, just curious what does the stock setup look like?
Offline calj737
  • I refuse...
« Reply #7 on: February 23, 2016, 04:33:52 am »
Ryan - use rivet nuts installed into the grab bar/frame, then a button head cap drew with a fender washer to bolt the cowl to the bike. Clean, smooth and quick detach.
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #8 on: February 23, 2016, 06:33:56 am »
Okay, fixed the V. Here is what it looks like under there.
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #9 on: February 23, 2016, 07:17:35 am »
But I think I would have to change the design to cover the grab bar for that kind of attachment. I suppose I could make a few tabs that come out and just make them rounded on their tips so they look ok. I'll mess around with it.
