Author Topic: OEM t/y connector barb  (Read 1107 times)
Offline ChopSticks
« on: February 22, 2016, 08:11:54 pm »
For tanks with one petcock outlet was there ever an OEM t/y connector/barb to split the fuel to the two fuel hoses of the carbs? Can't seem to find the OEM part number anywhere
Offline mystic_1
  • 1970 CB750K
Re: OEM t/y connector barb
« Reply #1 on: February 22, 2016, 09:09:29 pm »
Looks like the F models used 16235-657-000, Joint, Fuel.
mystic_1
- John Augustus Shedd
Offline ChopSticks
« Reply #2 on: February 22, 2016, 09:15:29 pm »
Thanks so much! Exactly what I was looking for!
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: February 22, 2016, 09:21:07 pm »
I've also successfully used brass 1/4" tees from the hardware or auto parts store.  Cheaper and easier to find.
mystic_1
Offline ChopSticks
« Reply #4 on: February 22, 2016, 09:24:56 pm »
only wish that was the case around here, tried two home depots and two local hardware stores to no avail. smallest I found was a 1/4 connector (female) and had to get 3 individual 3/16-1/4 straight barbs (~$15) to fit in each one which I felt was a bit ridiculous
Offline RevDoc
« Reply #5 on: February 23, 2016, 07:34:48 am »
You don't show on your profile where "around here" is but, I've never had a problem locating brass fittings like that in Home Depot or Lowes. If not in plumbing look where tubing and fittings  for refrigerator ice maker/cold water supply are. Also readily found in auto parts stores.
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
Offline ChopSticks
« Reply #6 on: February 23, 2016, 07:41:32 am »
I'm in NYC so our hardware stores are not as big/extensive as outside the city
Online dusterdude
« Reply #7 on: February 23, 2016, 03:23:54 pm »
Local auto parts store,ask for motormite,they make that tee
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
