Support the site. Your contributions keep this site running.
Test: Setup: On the centerstand, push up on the bottom row of chain, dead center. If the old chain on old sprockets, can be pulled away from the sprockets (at 3 Oclock on the rear sprocket) then need new chain. IF new chain on old sprockets can't be pulled away, then keep the old sprockets at lesat one more chain.If new chain can be pulled away from old sprocket, time for sprockets.
Quote from: MCRider on July 06, 2014, 04:45:03 pmTest: Setup: On the centerstand, push up on the bottom row of chain, dead center. If the old chain on old sprockets, can be pulled away from the sprockets (at 3 Oclock on the rear sprocket) then need new chain. IF new chain on old sprockets can't be pulled away, then keep the old sprockets at lesat one more chain.That is the way I check. You can usually have a set of sprockets last through two chains if the chain is lubed. If not the chain eats the sprocketIf new chain can be pulled away from old sprocket, time for sprockets.
