I want to make my own filter using green Uni-Filter universal foam that sells in a sheet of foam.I want to know what good quality,strong glue have you used to get a real good,tight bond between both pieces of foam? I'll be removing the element many times to wash out and re-oil so i want to get the best glue. Does the glue gun stuff work ?
I plan on cutting across and matching both flat ends of the foam together and gluing along that length to build one round filter 'tube' that can be slipped on a round screen that i'll be using and back off again for washing w/ solvent,cleaning & oiling.
