Author Topic: Carb return spring holder  (Read 987 times)
Offline Sdsbassist
  • Gus, Austin, MN.
« on: February 27, 2016, 08:39:38 pm »
Was was twisting throttle and hears a ping and they would return. The bottom plate where the spine cates came free of wherever it belonged.
Where does it go?
Sent from my SM-N900V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline harisuluv
Re: Carb return spring holder
« Reply #1 on: February 27, 2016, 10:12:02 pm »
Instead of a fuel T, between 2&3 there is a little plate that goes in there with a hole in it.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #2 on: February 28, 2016, 07:07:02 am »
Unracking the carbs again, aren't i?
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #3 on: February 28, 2016, 07:07:30 am »
And I just reread my orig post and hate autocorrect.
Gus, Austin, MN.
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: February 28, 2016, 07:17:49 am »
The thing is, the shape of the plate should make it basically impossible for it to "pop out", something would have to be seriously bent or broken for this to happen.
Ordinarily the ears of the plate are trapped quite deeply into recesses in the carb bodies.
Got pics?
mystic_1
- John Augustus Shedd
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #5 on: February 28, 2016, 07:32:16 am »
I had just unrack ed the carbs to replace a carb body. Guessing part or all of it came out them and when I cracked the throttle it popped out.
Gus, Austin, MN.
