Author Topic: Non honking horn - 500 four K0 1971  (Read 868 times)
Offline paulbaker1954
  • I 'll just be 5 minutes dear!!
« on: February 29, 2016, 04:59:29 AM »
Power there and all right coninuity through horn button so I have a broken/inoperable horn.
Can it be "freed" or serviced in any way before I dig in to the money chest again?
If you think there's light at the end of the tunnel it's usually another train !!
2014 Triumphy Trophy 1200
1971 Honda CB500 Four K0
Offline MoMo
  • Ride like you're invisible
Re: Non honking horn - 500 four K0 1971
« Reply #1 on: February 29, 2016, 07:14:16 AM »
I wire 12 direct to the horn.  If it blows then  the switch is the problem.
Offline Flyin900
« Reply #2 on: February 29, 2016, 07:16:38 AM »
Test the horn with a known 12V source to confirm it is dead. There is a small screw and nut on the back or the horn that applies some pressure to the inside diaphragm. By just releasing and fine tuning the screw it will sometimes start the horn working again, then lock down the nut on the screw again. You only need to make a fine adjustment here not a couple of turns.
Other times it is a dead horn and time to replace it
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline CB650CPastor
« Reply #3 on: February 29, 2016, 08:43:49 PM »
My horn wasn't working when I bought the bike. I tried all of the external fixes and then carefully pried it apart. It was full of rust. I cleaned it out, sanded the contacts, made a new paper gasket, put it back together, and recrimped the edges. It works great now. I have a spare that works. I just wanted to see if I could fix it.
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
