Another consideration about using AUX is the number of total wires that will be plugged into it. Without using their multi-port connector, you can only plug 2 wires in. You'll need AUX to supply: ignition coils, gauge backlights, tail light, idiot lights, and possibly a license plate light. You'll be splicing so many times to make those connections, that your R/R is bound to be reading an incorrect voltage.
