My guess is this is carb related. It kick starts just fine, requires choke to start. Idles fairly okay when playing with choke.
Has a hard time climbing the revs, wants to die when you give it too much throttle. Biggest issue is, even if you get WOT and its running alright, it still will not climb over 4k. When you shut down the throttle after attempting to rev it higher, it usually will die.
Using the stock airbox, but the PO cut the muffler(s) off, so its 4 straight pipes that are cut off under the motor.
My guess is the chopped exhaust isn't helping, and possibly the carbs need attention.
Could it be anything else? Ignition related? It appears to be firing on all 4 just fine.
I just adjusted the valves, BTW. Intake was fine, exhaust was tight. Otherwise okay.
Thanks all.
