Author Topic: 16mm Bolt-In Tachometer Elimination Plugs Available for Honda CB550/650/750  (Read 921 times)
Cooper Custom
For anyone looking to eliminate their tachometer or run a digital tach on their late 70's/early 80's Honda CB550/650/750, we have custom made ones for sale.
Cooper Custom tach-plugs are made by hand from T6 aluminum. Anodized in red, blue or black for a durable finish. They are fastened in place using the M6 tapped hole already in your cylinder head from where your tachometer cable was mounted. It also features a double set of "o" rings and comes with stainless steel M6 socket head cap, screw and lock washer (eliminating the Philips screw). It's made from two pieces and is permanently pressed together on a hydraulic press. All bolts, washers and "o" rings are included.
This is a limited run with the anodized finish, so don't wait.. they sell out quickly.
Any questions, feel free to contact us directly at cooper.custom@hotmail.com
Follow us on instagram: https://www.instagram.com/cooper_custom/
Purchase on Ebay: http://www.ebay.ca/itm/16mm-Bolt-In-Tach-Plug-for-Honda-CB550-650-750-/322019817251?hash=item4af9e07723:g:xrAAAOSwG-1W0GC4&vxp=mtr
The plugs pictured will not work on a SOHC 750? How well do you know these bikes?
Offline harisuluv
1 post ever, Shameless plug.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Shameless plug.
I see what you did there.
--Evan
1975 CB750K "Rhonda"
