Author Topic: New Member in Colorado  (Read 1516 times)
Offline RyanM
« on: March 03, 2016, 04:06:20 PM »
Hello everyone!
I picked up my first bike this summer. Its an 1982 CB650SC. I got a pretty good deal on it and it only has 7,000 miles and it runs pretty good. I'm hoping to do a cafe build. Nothing too radical because the previous owner took such good care of it.
A couple of problems I'm having with the bike...
In lower rpm ranges the bike will lurch under acceleration. It doesn't matter what gear but after that it runs great. Any ideas on what could cause that?
Also, occasionally I will find a false neutral when shifting from 4th to 5th. Is that a sign that my clutch could be going out?
Thanks for your help!
1982 CB650
Re: New Member in Colorado
« Reply #1 on: March 03, 2016, 06:30:01 PM »
Colorado is a large state?!
Member CB650 is in 'Colorado' also. He might be a good resource for you.
« Reply #2 on: March 03, 2016, 06:40:22 PM »
Welcome...these bikes don't have much low end torque.  All the power is at the top of the tach.  Try riding at higher rpms.  I am not very familiar with the 650, but the 550, which is very similar mechanically really does not make decent power until at least 4500 rpm.  False neutrals are not caused by the clutch.  Try to be very deliberate when you shift these, many like to put a little gentle pressure on the shifter ahead of time, then when the clutch is pulled, clunk the shifter home firmly.  False neutrals can also be caused by transmission problems such as bent shift forks or worn out gear dogs.
Offline RyanM
« Reply #3 on: March 03, 2016, 08:59:19 PM »
Thanks you! I'll try to focus on that when shifting and see if the problem persists. I only started riding last summer. I just thought it was strange that it only happens between 4th and 5th gear..
1982 CB650
Offline RyanM
« Reply #4 on: March 03, 2016, 09:08:03 PM »
Thanks. Ill have to reach out to him. Looks like you are in Colorado as well?
1982 CB650
« Reply #5 on: March 03, 2016, 09:28:06 PM »
Yes I am. I'm in the Springs. If you're out for a ride one day stop on by.
Offline cb650
« Reply #6 on: March 04, 2016, 01:28:34 AM »
Ryan what part of the state you in?   The false neutral could be a weak spring in the shiftier of just needs a couple oil changes.
« Reply #7 on: March 04, 2016, 04:54:47 AM »
Welcome, Ryan.
Offline RyanM
« Reply #8 on: March 04, 2016, 03:54:44 PM »
Okay thanks. I'll look into that. I rode it to work today and I think shifting more deliberately helps but it still happened a couple of times... I'm in Lakewood. What about you?
1982 CB650
Offline RyanM
« Reply #9 on: March 04, 2016, 03:57:37 PM »
You're a little south of me but ill keep that in mind if I'm ever down that way!
1982 CB650
Offline cb650
« Reply #10 on: March 05, 2016, 12:21:43 AM »
Im out in hudson.    30 miles out on I=76      Do you also have a nitehawk?
Offline RyanM
« Reply #11 on: March 08, 2016, 05:17:29 PM »
Oh that's not too far. I don't have a night hawk just the 650SC. I was a little confused on the model when I first bought it.
1982 CB650
« Reply #12 on: March 08, 2016, 08:18:57 PM »
Yeah, Terry is "OUT IN HUDSON".  ;)That's just north of BFE  ;D Maybe one day we can meet up for a ride. He's definitely your resource for 650's.
Offline cb650
« Reply #13 on: March 09, 2016, 03:02:27 AM »
Ok your tag said nitehawk but pis shows a standard.  Come out anytime just give warning.   Work nites so sleep schedule is all fd up.  Havent been doing much with the bikes lately as I have a new 4 wheel toy to call the money pit.
Offline RyanM
« Reply #14 on: March 11, 2016, 05:35:40 PM »
I'd be up for a ride sometime! Thanks again for your help.
1982 CB650
Offline RyanM
« Reply #15 on: March 11, 2016, 05:38:09 PM »
Yeah, I learned mine was a standard just recently. I swear the previous owner said it was an SC nighthawk...
1982 CB650
Offline RyanM
« Reply #16 on: March 11, 2016, 05:45:25 PM »
This might be a dumb question but I'm trying to learn... haha
I was going to adjust my air mixture screw but there is a hose going into where I think the screw is supposed to be on one of the carbs.. What do I need to do to adjust the air mixture on that one?
Thanks
1982 CB650
Offline cb650
« Reply #17 on: March 12, 2016, 03:16:10 AM »
those are the sync ports.  That hose goes to the fuel auto shut off.  Air mix is on the bottom and they are limited if still stock.    I did get the 360 out for a a ride yesterday.  Dam thing just sits and sits and just starts right up.    Old bike ride is coming up soon.
