Author Topic: Removing pin holding in gas cap  (Read 945 times)
Offline Bristledisk
« on: March 03, 2016, 05:14:40 PM »
Hi All,
What's the best way of removing the pin holding in my gas tap on my 1976 CB400F?
The pin appears to be riveted in place.
Thanks
1977 CB400F, 1976 CB750F1, 1974 CB550K, 1975 CB550K, 1976 CB550K2, 1973 CB350F
Offline MoMo
  • Ride like you're invisible
Re: Removing pin holding in gas cap
« Reply #1 on: March 03, 2016, 05:17:13 PM »
small pin punch after grinding off the flare.  That pin does not look stock...Larry
Offline 540nova
« Reply #2 on: March 03, 2016, 05:29:15 PM »
REPLACING that pin was the hardest part of the total overhaul of my 74 CB450! The little spring fights you. Have fun with that!
Offline Johnie
« Reply #3 on: March 03, 2016, 05:34:37 PM »
I drilled a little bit of the rivet flange off and when I pushed it through the edges collapsed. They I reused it and pushed the flanges back out with a BB and c-clamp. Just do not bang to hard when you try to get it out or you will bend the hinge post.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
