Author Topic: Cam chain tensioner CB 650 1982  (Read 2231 times)
Offline andreasj55555
« on: March 07, 2016, 08:36:31 AM »
Hey someone that knows!?
I just rebuilted my engine and put it together and in to the fram.
The only thing that worries me is the cam chain tensioner. There whasent any information in how to tight it and how close it should be to the cam chain.
There are two screews on the outside of the cylinder. One for the tension and one for the higher and lower it.
Before I put the engine together and closed it up I screewed the tension screw so the plastic bow that sits into the metal bow about 1cm from the chain. My toughts were to adjust the tension after starting the engine up.
Is it possible to adjust it that way? Or do you need to take the head of?
Please help.
Thanks Andreas from Sweden:)
Skickat från min iPhone med Tapatalk
