Author Topic: Long filter housing or short?  (Read 1312 times)
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
« on: March 07, 2016, 04:09:06 PM »
I have both the long filter housing and the short one for my 1978 CB750k. Which would be better? My thinking is that the larger one would hold more oil. Any ideas on this?
        Thanks, Doug
Re: Long filter housing or short?
« Reply #1 on: March 07, 2016, 04:18:40 PM »
Why would more oil be better?
I dont recall Honda making different volume oil filter housings. . .
The F's had an additional plate for cooling purposes.
« Last Edit: March 07, 2016, 04:21:15 PM by flybox1 »
Offline Doggie
« Reply #2 on: March 07, 2016, 08:41:07 PM »
On my 1980 CB650C, there is a long housing with a spacer. I have an extra one. Just wondering if it would be good on the CB750k that i'm building. I know race auto engines have larger pans for more oil.
Offline kmb69
« Reply #3 on: March 07, 2016, 08:57:24 PM »
Should work just fine. Certainly wouldn't hurt. Same principal as the autos.
Offline Doggie
« Reply #4 on: March 07, 2016, 09:34:43 PM »
Great......Thanks for the info.
Offline City Boy
« Reply #5 on: March 08, 2016, 05:52:36 AM »
Hi.I use the longer housing on both my 1100F and 750.They hold 6 oz's more oil.More oil can't hurt hurt in my view.Is it necessary,probably not.The housings I use are from 400F's.The 1100F likely more important use being it is wet sump.
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
« Reply #6 on: March 08, 2016, 06:04:34 AM »
My K0 takes exactly 3Q of oil, unlike later models.  More oil is better, imho.  More additives to go around, bigger mass of oil to take away the heat.
Offline City Boy
« Reply #7 on: March 08, 2016, 03:54:54 PM »
I put the later oil tank on my unit as I liked the slimmer look of the side covers.Fortunately I had saved the original tank till about 3 years ago and unloaded it for sandcast money.Coupled with the large Lockhart cooler with the pipe fittings tapped into  the return circuit and a CR relief spring in the pump I have been very pleased with the lube system.
     Rock On
'83 1100F
Offline Doggie
« Reply #8 on: March 10, 2016, 08:06:11 PM »
I'm leaving the short one on for engine painting, then putting the long one on. Thanks for all the info.... Doug
