Author Topic: KONI shock internals  (Read 2319 times)
jsaab2748
« on: November 11, 2006, 12:33:17 PM »
Would anyone out there have a diagram of the internal parts of a 1296(?) Koni to fit a k5 750? I took one apart a while back, and can't remember the sequence and orientation of the guts. Also, what kind of fluid to put back in and how much? Is automatic transmission fluid ok? Fork oil? I could dis-assemble the other shock to see how things go, but would rather have parts diagram to be safe. Thanks in advance. jim
Rocking-M
Re: KONI shock internals
« Reply #1 on: November 11, 2006, 03:21:10 PM »
do a search on Koni's. I run them on my cars and have found a lot of info.
on rebuild etc... as best I remember I went to Koni's site and they had
diagrams. Hope this helps.
Rocking-M
« Reply #2 on: November 12, 2006, 05:52:34 AM »
what is the shock number. Should be on the side somewhere. I'll see what I can find.
jsaab2748
« Reply #3 on: November 12, 2006, 09:41:21 AM »
7610-1296 is the part number for the rear shock for a 750 k model. Again, thanks for any info.
Rocking-M
« Reply #4 on: November 12, 2006, 09:59:26 AM »
Try this, scroll down and you'll see the 76 series listed. I'm not sure they have a schematic for parts but you may be able to
contact them for it.
http://www.koni-na.com/adjustment.cfm
As to oil, Koni uses a secret oil, though I know of different oils being used
to stiffen the shock a bit. You could experiment but if you don't want it to stiff
just go with the fork oil and you should be ok. (My 2 cents on that).
Hop on a Honda
« Reply #5 on: November 13, 2006, 03:10:09 AM »
KONI is now an Australian Company1
The new name is IKON
www.ikon.com.au
Dave
Offline Clyde
« Reply #6 on: November 13, 2006, 08:50:50 PM »
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
