Author Topic: CB550 Throttle Issue  (Read 1060 times)
Offline 550Resto
« on: March 15, 2016, 12:24:31 PM »
Hello all, so I've searched and can not find a similar post to my problem. I replaced both the push and pull cables on my 78 550 with new motion pro cables. The old ones were original Honda cables. The issue I have is the top cable (I believe push) seems like it's too short. However when putting new vs old the new are slightly longer with the sheath, but same length cable wise. Not sure what's going on, but it's frustrating. Any and all help appreciated.
I alsace sure to replace the like cable for the new so I'm sure the cables are I'm the right spot. It seems as though if I did get the push cable attached it would be way to tight.
Offline Deltarider
Re: CB550 Throttle Issue
« Reply #1 on: March 15, 2016, 12:51:01 PM »
If you study p.49 of the parts list http://www.honda4fun.com/pdf_parts_list/pdf_spac500-550/CB500-550_K3-K4.pdf, you'll find that Honda had different cables for different (height) handlebars. Could it be that Motion Pro has mixed up?
CB500K2-ED Excel black
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: March 15, 2016, 12:52:52 PM »
I think you hit the nail on the head. If the new casing is longer than the original that will cause your problems. FWIW The numbers to the "A" cable are different from the old series (74-76) to the new series (77-78) of 550.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline thirstforspeed
« Reply #3 on: March 15, 2016, 12:56:14 PM »
I have this same problem with my CB550 resto. The casing on the new MotionPro cable is maybe 1/4" too long (there is not enough cable sticking out of the sheath to connect it.
I used my old cable in the meantime.
Please advise if you find another part number that works for this.
Offline 550Resto
« Reply #4 on: March 15, 2016, 03:07:11 PM »
Well it seems the stock cables worked just fine. Put them back on and lo and behold they fit! I'll have to source some new stock Honda cables. Thanks for all the help! Also included pictures of the motion pro cables. Nor sure if anyone can use them.
Offline radiowar
« Reply #5 on: March 15, 2016, 07:19:37 PM »
Interesting. I just installed a set of Motion Pro's on my CB550k. Stock handlebars and PD46C's. Never had any issues getting the cables on.
I ordered them from 4into1, and here are the specs according to them.
Throttle Pull: 45.5" total length - 39.75" housing - 5.75" slack
Throttle Push: 45" total length - 41.75" housing - 3.25" slack
Clutch Cable: 53" total length - 49.5" inner housing - 3.5" slack
Motion Pro part number: 02-0005 (clutch), 02-0155 (pull), 02-0156 (push).
A fish in the bush is worth two in the pants. — Benjamin Franklin
78' CB550K
« Reply #6 on: March 15, 2016, 07:32:14 PM »
This comes up from time-to-time because of the similar nature of the cables between the PD early and late carbs. On the 750, it is the difference between the non-PD and the PD carbs, and has the same problem.
The carbs that have the "drawspring" that closes the throttle uses the pull cable with the shorter length core. The carbs with the integral clockwind spring(s) for return use the longer-extending cables.
