Author Topic: CB550 Headlight "Spaghetti" Help!  (Read 1944 times)
Offline davidru2
  • New rider of a 74 CB550
« on: March 18, 2016, 10:05:28 PM »
Main headlight on my 74 CB550 stopped working.  I checked the headlight and it works, but not sure what the problem is.  There's so many wires behind my headlight it looks like electrical spaghetti!
All I know is that the ground works as does the light when I go direct to the batt., I also cleaned the connections and that hasn't helped.  I'm a bit confused as to what the blue and white cables even do.
Please help, don't even know what to look for here.
Offline mystic_1
  • 1970 CB750K
Re: CB550 Headlight "Spaghetti" Help!
« Reply #1 on: March 18, 2016, 10:11:55 PM »
You've checked the headlight fuse, I hope?
White is +12v power to the low-beam filament, Blue is +12v power to the high-beam filament.  Green is ground, of course.
You should be able to measure +12V on one or the other of the blue or white wires, if not, start working backwards.
The headlight switch is powerd from the BRN+RED (?) wire that leads to the headlight dimmer switch from the fuse block..
If you have no power there, check for +12v at the BROWN wire coming from the key switch.
Somewhere along the line you'll find the spot where you don't have voltage, but should.
Are the rest of the electrics are working properly?
mystic_1
« Last Edit: March 18, 2016, 10:17:28 PM by mystic_1 »
- John Augustus Shedd
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
« Reply #2 on: March 18, 2016, 10:16:37 PM »
The good news is that you have what looks like a stock and very clean wiring harness. Get the wiring diagram and learn. 12v systems are surprisingly simple and those Honda engineers made the diagrams pretty easy to follow.
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Offline CB650CPastor
« Reply #3 on: March 19, 2016, 10:15:45 AM »
Green is ground/earth, blue is high beam, and white is low beam. Check all of the connections from the switch, clean all connections, clean and verify the switch is operational with a meter, verify fuse continuity with a meter, check wire continuity with a meter. That's all there is in the system. If you do all of that, you'll find the problem.
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
Offline davidru2
« Reply #4 on: March 19, 2016, 01:14:13 PM »
I haven't, I wasn't sure where it was.  I'm going to look it up now --very helpful - thanks!
Offline davidru2
« Reply #5 on: March 20, 2016, 03:18:00 PM »
The Fuse was the culprit!  The fuse box was hidden as the previous owner changed the location to make room for a new rectifier!
THANKS EVERYONE !
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: March 20, 2016, 04:52:48 PM »
Ah excellent.  Simple fix!
mystic_1
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #7 on: March 20, 2016, 04:54:03 PM »
FWIW, I ran into this exact problem the other day, and I know my headlight bucket's rat's nest inside out... It was ALSO the fuse and ALSO the last thing I checked!
New fuse... let there be light!
--Evan
1975 CB750K "Rhonda"
« Reply #8 on: March 21, 2016, 04:20:22 AM »
Fuse should not blow without reason. I hope you have found out why when it can blow again. Hopefully correct fuse (number of A)
