Author Topic: '76 CB400F work in progress - rear suspension mount point sheared  (Read 1369 times)
Offline mwalters
So, crap. I'm working on restoring / customizing a '76 CB400F for my wife's 40th birthday, with step 1 being getting down to the bare frame so that I can de-rust and paint it. Last night, while removing the rear suspension, this happened:
So. It seems like the best thing to do is to cut back the mount a bit, and weld in a new section of shank and thread, but I'm wondering if anybody else has experienced this issue, and if so, how you resolved it. I could use some input here.  :-\
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
Re: '76 CB400F work in progress - rear suspension mount point sheared
« Reply #1 on: March 21, 2016, 11:50:27 AM »
mwalters ; While slightly different vehicle. I had the same thing happen on my 1992 Ford Ranger front shock. I took a bolt with the same threads, ground one end down to a rather sharp point. Then welded it what was left on the vehicle. The main concern was keeping it straight. But I do have welding experience and my own equipment . Just my 2cents!   ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: March 21, 2016, 11:56:49 AM »
Your idea should work.  All stress is on the mount and that is solid-the nut retains the shock from moving side to side so you  could have a high grade bolt welded on....Larry
Offline calj737
  • I refuse...
« Reply #3 on: March 21, 2016, 01:12:47 PM »
You can also buy new shock mounts and weld them in, or have them pressed in.
Online Don R
« Reply #4 on: March 21, 2016, 01:21:18 PM »
I found tubing that fit over the shock mount, then bushed it down to the thread size making a drill guide. Then I drilled it through, bought a bolt the correct length. Cut off the head and inserted it through the mount. Then I welded the back side.
« Reply #5 on: March 21, 2016, 06:41:05 PM »
You could also drill and tap the mount for a short 5/16" or 8mm bolt.
Offline camelman
  • Man... Myth... Legend
« Reply #6 on: March 21, 2016, 09:15:36 PM »
There isn't much sideways load on that bolt at all. I expect that simply welding some threaded stock onto the mounting point will be sufficient just like Cougar did. A decent weld at a location like that would easily hold hundreds of pounds of tension, and you'll never see that kind of a sideways load from the shock.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline mwalters
« Reply #7 on: March 22, 2016, 08:17:41 AM »
Thanks much, all. I had been considering that there wasn't much lateral loading on these threads, and the idea of drilling out the mount, tapping in new threads, and just threading in a new length of appropriately threaded rod seems pretty appealing at this point. I can just as easily weld and then use a die to chase the threads down over the welded area, though.
Hmm. I guess I'll figure out what thread pattern it is and then see what I can find to replace it.
Offline mwalters
« Reply #8 on: March 27, 2016, 05:33:18 PM »
It's M10x1.25 (M10 fine), for future reference. I spent a bit of time with my welder and bodged on a fix:
Far from perfect, but it will do the job.
Also finished getting the frame into black today:
This is the VHT Chassis / Rollbar paint in matte. I think it looks great!
« Last Edit: March 27, 2016, 05:36:02 PM by mwalters »
