Author Topic: CB550F clutch washers?  (Read 1200 times)
Offline Jenny_caferacer
« on: March 23, 2016, 04:54:01 PM »
im looking at the diagram #15. is this a thin washer or thick one?
Re: CB550F clutch washers?
« Reply #1 on: March 23, 2016, 05:22:29 PM »
#14 is a thicker thrust washer, whereas #15 is very thin and fits under the circlip on the end of the mainshaft. There were three thickness options for #15, a 0.1mm, 0.3, and a 0.5mm very thin but none of which are available from Honda anymore. The one in your hand I expect is a .5mm. Keep in mind there needs to be a slight amount of end play on the mainshaft. I believe they state 0.004" maximum end play.
Offline flatlander
« Reply #2 on: March 24, 2016, 04:13:14 AM »
brent you're right, the manual give 0.004" as max play. but as far as i can see it does not say anything about a minimum amount of play. where did you find that described?
i think david silver spares used to have those thin spacers, except the 0.1mm ones.
« Reply #3 on: March 24, 2016, 10:16:22 AM »
As long as there is some clearance....you know, between some & 0.004"!  ;)  Not tight...I suppose that's the minimum!
Offline flatlander
« Reply #4 on: March 24, 2016, 01:32:38 PM »
so on a precise scale i guess that means something between tiny and almost nothing - but not nothing ;)
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=o6f5m503v79qv250rh1jgmrs75&/topic,60973.0.html
« Reply #5 on: March 24, 2016, 01:38:12 PM »
not nothing ,is very less... ??? ::)
i hate all this v-w.... vords
Offline flatlander
« Reply #6 on: March 24, 2016, 01:40:40 PM »
now you're just being pedantic about nothing  ::)
