Author Topic: thange rubber pucks to metal freeze pop aut seals..on cb heads  (Read 550 times)
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=i7jaajtudo61e1i4mijv0b4ko5&/topic,60973.0.html
have any tried to use this teller formed discs..vho get a hammer cnock,, and then make a press teighting,,by deform a bit..think they vas a better idea then the rubber pucks..vho often not is korrekt/aftermarked bad kvality..they are easy to remove...just drill them and carefull breake them up--
please translate/korrekt my vriting :P
« Last Edit: March 24, 2016, 01:36:42 PM by strynboen »
i hate all this v-w.... vords
Re: thange rubber pucks to metal freeze pop aut seals..on cb heads
« Reply #1 on: March 24, 2016, 01:48:00 PM »
brass.
I made some out of brass to go under some undersized pucks.
I eventually found some pucks with adequate thickness, and did not use these shims.
« Last Edit: March 24, 2016, 01:58:57 PM by flybox1 »
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: March 24, 2016, 07:58:33 PM »
Hey that's a pretty interesting idea, to use freeze plugs to replace the sealing pucks entirely.
I'm only familiar with using these in automotive engines with steel blocks, do they use these on aluminum engines also?  I'd be worried about deforming the hole from applying enough force to achieve an oil-tight seal.
mystic_1
- John Augustus Shedd
« Reply #3 on: March 25, 2016, 12:41:15 AM »
Aluminum plugs would be better to keep the expansion rates similar...
Offline strynboen
« Reply #4 on: March 25, 2016, 04:21:32 AM »
yes made in 3mm aluminium vill be perfekt.. dont hurt the alu cast..so steel plugs is not perfekt..i think....but how thik can they be..to fit inn the engine
