Author Topic: Rear Wheel Sprocket Teeth Alignment  (Read 1828 times)
Offline Popwood
« on: March 26, 2016, 12:46:12 PM »
I'm changing out the sprocket on my '75 750k, replacing a 48 tooth sprocket with a new 48 tooth from JT Sprockets. The new one is the same diameter and fits on the studs just fine. But when I lay the old sprocket over the new one, the teeth fall right in the middle of notches of the other sprocket teeth. Is this an issue? I would think not but just checking.
Thanks
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline rotortiller
Re: Rear Wheel Sprocket Teeth Alignment
« Reply #1 on: March 26, 2016, 12:56:35 PM »
So long as the teeth will overlap exactly is all that matters-sounds like they do (same pitch). The position of the drive bolts matters not so long as it fits on the hub properly as you say it does.
Offline Popwood
« Reply #2 on: March 26, 2016, 12:58:27 PM »
Thanks, rototiller!
Current Rides:
1975 cb550K
1975 cb750K
Past Rides:
1988 400 Hawk
