Author Topic: Stev-o's K3 "Park Racer"  (Read 89502 times)
Offline edwardmorris
  • Youngish
Re: Stev-o's K3 "Park Racer"
« Reply #200 on: May 18, 2016, 08:17:56 AM »
Those gauges are unbelievable! I'm sure it's been said on here, but does Marcel reuse the old glass, or use something better than original that maybe has some uv protection for the faces?
His full rebuild service uses new outer housings, lenses, faces and crimp rings IINM. Not sure about the UV protection thing, but the new lenses sure look great! I just rebuilt my K3 gauges using new lenses and facing last night, my 4th set so far and Marcel's stuff is top notch 8)
Not the best pic, but I think they came out good..
« Reply #201 on: May 18, 2016, 09:56:37 AM »
Every set of gauges out of his shop that I've seen looks pretty spectacular.
« Reply #202 on: May 18, 2016, 02:21:29 PM »
Ok ok....enough free advertising for Marcell!
I did that for a joke, since Nils was insisting on an update.
I have no plans for a speedo on the Park Racer!  Prolly tach only, just as it came to me.
« Reply #203 on: May 18, 2016, 03:17:23 PM »
Shoot! Now we have to wait until you get out of paint jail.  Just that, wiring and tuning, right?
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #204 on: May 18, 2016, 03:55:21 PM »
Oooh, you got me!
Even so, great update :-)
« Last Edit: May 18, 2016, 03:57:40 PM by NobleHops »
I have a motorcycle problem.
« Reply #205 on: May 19, 2016, 02:34:53 PM »
Ok, back to business. I was out of town last week, so not much has gotten done.
However, I did go shopping for engine paint sine member Riverman said he HATES the New Ford Gray color!
Don mentioned O'Reilly's, but the only had Duplicolor "Cast Coat Iron", what do you guys think of Duplicolor?
The color is what I originally had in mind, dont want stock, this shade will provide sharp contrast next to the polished covers.
« Last Edit: June 26, 2016, 07:28:39 PM by Stev-o »
« Reply #206 on: May 19, 2016, 02:50:21 PM »
Now I'm not going to pull the motor just for paint at this point but I brought the bike to my buddy's shop for a leak down test.
For those that are not aware, a leakdown test will tell you more than a  compression check.
Basically, the cylinder is put at TDC on the compression
stroke (valves closed and piston at top), then pressurize the cylinder to 100psi. A gauge on the tester that will tell you what the cylinder is holding after 10 min.
My motor failed miserably!  I dont have the numbers in front of me but #3 was at 50%  [Ideally, you want 90%].
So the top end came off, it's nice having the frame kit!  So now, I'm in "machine shop jail", getting a valve job and I'll find out tomorrow if the jugs will be within spec after a precision hone.
I'm hoping to hone and rering, but if I'm not lucky, it will be getting the ebay $130 Big bore kit!
The tensioner was quite worn, I have a few spare, and on a good note, the cam and chain look fine.
Offline Jeffro93
« Reply #207 on: May 19, 2016, 03:07:02 PM »
I used Cast Coat Aluminum on the non-Nils engine parts.  I've actually painted a few non-engine parts with it as well.  I think it looks great...
1974 Honda CB550
1983 Honda GL650 Interstate "Cafe'd"
2007 Triumph Bonneville
« Reply #208 on: May 19, 2016, 03:16:46 PM »
That does look good, thanks Jeff. My main concern is durability....
Offline Jeffro93
« Reply #209 on: May 19, 2016, 03:39:47 PM »
Can't help you on that one...  I cleaned and degreased the best I could for not pulling the case apart.  The paint is supposed to be good up to 500 degrees...
1974 Honda CB550
« Reply #210 on: May 19, 2016, 04:04:28 PM »
Looks good.  It's always tough to see how the color looks in different light.
Both of these motors are VHT Cast Iron
My 750
My 650
The following are the same paint and motor, showing how ambient lighting and exposure settings make them appear very different in photos
« Last Edit: May 19, 2016, 04:07:00 PM by CB750 Cafe Racer Fan »
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #211 on: May 19, 2016, 05:42:24 PM »
So you're not pulling the engine?  Are you going to repaint it in the frame?  The Duplicolor gray looks good to me.  I'm painting my cases a similar gun metal gray, hopefully on Saturday.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline NobleHops
« Reply #212 on: May 19, 2016, 09:31:48 PM »
Pulllll eeeeeeeet.
« Reply #213 on: May 19, 2016, 10:54:12 PM »
If you're down to the crankcase, just PULL IT.
Offline Restoration Fan
  • My wife will never call me
« Reply #214 on: May 20, 2016, 04:32:31 AM »
It's your time & money, Stev-o but I agree with Don.  Since you have a frame kit and already have the top off, it's much less work to pull the engine and paint it out of the frame than it would be to mask off everything else on the bike to paint it in the frame.
Offline tweakin
  • tear down
« Reply #215 on: May 20, 2016, 05:54:03 AM »
What Don said  ^^^^
« Reply #216 on: May 20, 2016, 06:56:24 AM »
Havent even decided if I'm going to paint
« Reply #217 on: May 20, 2016, 08:53:26 AM »
I was initially thrown off when Jeffro posted an engine being painted, and thought it was your post.
That said, now's the time if you are going to do it.  Might as well with the engine this far disassembled.
Offline NobleHops
« Reply #218 on: May 20, 2016, 03:42:16 PM »
We're totally ganging up on you here...
Offline calj737
  • I refuse...
« Reply #219 on: May 20, 2016, 04:57:26 PM »
Let it be. Run the dog piss out of it this season, pull it for Winter, drop in a Wiseco 836 kit, a Stage 4 head, then have Nils do his Spa Day on it!
Always a dissenter in the group...  :-X
Offline riverfever
« Reply #220 on: May 20, 2016, 07:51:09 PM »
This may sound biased but I'm just excited to know that I got rid of the "fever" and now I'm "man."  8)
Sorry to hear about the results of the leak down test Steve. That sucks.
« Reply #221 on: May 20, 2016, 09:43:46 PM »
I don't succumb to peer pressure!
Offline Cityscapedview
« Reply #222 on: May 25, 2016, 11:27:01 PM »
Great work so far,  curious to see how this build progresses.
1971 Honda CB 500
David
« Reply #223 on: May 26, 2016, 07:17:18 AM »
The weekly update is no update!
I'm still in "machine shop jail" but last word from the shop was he thought the cylinders would hone out and be within spec.
I was happy to hear it but surprised - I was expecting the worst.
Boring would be $200 plus the cost of a piston kit [$400?], he's a Wiseco dealer and talked me into Wisecos on both my Kawasaki rebuilds [no regrets]
I really had hoped it would be running by now. We're into boating season and the wifey insists on being out on the water rather than having me in the garage!
My plan for this weekend:  Beer, boating, biking & BBQ, not necessarily in that order!
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #224 on: May 26, 2016, 07:38:39 AM »
That sounds like a perfect Memorial Day weekend! Can we come?
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
