Author Topic: Fuel tank patch?  (Read 913 times)
Offline Jon T
Fuel tank patch?
« on: March 27, 2016, 10:36:58 AM »
I have this tank, it's not in that bad of a condition. Inside is going to need a lot of work. I'm here cause it looks like the previous owner might have patched the tank. I'm wondering what you're opinions on it, if it even is a patch job. Mainly would I be better off getting a new tank? Money is getting a little low for this build, so I like the idea of refinishing this tank. I found this body set for $1200 (USD) from yamiya.com. I need an airbox anyway so it looks like a good deal. But if I can salvage this tank and refinish it and order an airbox off eBay, it will be much cheaper. I have some pics
Re: Fuel tank patch?
« Reply #1 on: March 27, 2016, 11:00:53 AM »
  Best thing to do is de-rust it inside and see if any more major holes develop and then if nothing major give it a good inner seal coat like Caswell or Red-kote. Not a Kreeme fan here but some have had good luck. Looks probably salvageable from what can be seen.
  That looks like solder they used for the patch ?  Better than JB if they did it correctly.
« Last Edit: March 27, 2016, 11:04:33 AM by ekpent »
