Author Topic: Fork oil question  (Read 1119 times)
Offline 75 super sport
Fork oil question
« on: March 27, 2016, 02:15:20 PM »
I just changed the fork oil  on my 75 cb750f.  The forks were soft before I changed the oil, and I thought they might be low on fluid so I changed it. I used atf. I added 150 ml  (5oz) of fluif. They are still pretty soft, any ideas?
« Last Edit: March 27, 2016, 05:49:09 PM by 75 super sport »
"Smoke em if ya got em"
Offline Steve_K
Re: Fork oil question
« Reply #1 on: March 27, 2016, 03:59:02 PM »
Two things it could be.  Fork springs weak or you could add some spacers to increase spring pressure.   I have a 73 750K and I needed heavier weight oil.  20 wt fork oil is what I used.
BTW, I have progressive  fork springs in my bike.
Steve
Steve_K
« Reply #2 on: March 27, 2016, 04:35:25 PM »
I remember reading Hondaman post on using heavy oil - like 15w40 - in forks.
« Reply #3 on: March 27, 2016, 05:30:04 PM »
So I do have the correct amount of oil in there? I added 5oz which is about 150ml, which is what I was told to add. It would be 7oz if doing a rebuild of the forks correct?
Offline ofreen
« Reply #4 on: March 27, 2016, 09:11:27 PM »
The owner's manual for the '75 750F calls for 5.6 oz or 165 cc (ml) of ATF.  I use 6 oz of PJ1 71/2 wt fork oil in my '75F and check to see levels are the same in both fork legs.
Greg
'75 CB750F
« Reply #5 on: March 27, 2016, 09:14:27 PM »
How do you check the levels?
« Reply #6 on: March 28, 2016, 04:34:28 AM »
I use the oil level recommended by progressive. No springs in, fork completely collapsed, oil level 140mm from top
http://www.progressivesuspension.com/pdfs/forkSprings/3055.pdf
I use a big syringe with a hose that is 140mm in lenght from bottom of syringe. I fill with oil until level cover the hose with syringe bottom against tube, suck with syringe and oil level will become exactly 140mm
Photo when I changed leaking seals and filled fork before assembly. I have to remove handle bar to take out springs, then collapse lift front with jack or press bike down.
Will do this soon again when I need to replace fork tubes, one is scratched. OEM stuff going on front end
« Last Edit: March 28, 2016, 06:28:42 AM by PeWe »
