Author Topic: Removing Fuel Screen  (Read 1285 times)
Offline 550Resto
« on: March 30, 2016, 05:37:14 PM »
Hello all, I'm going to try and tackled my fuel tank this weekend, however I'm at an bump in the road. I am having trouble getting the screen out of the fuel tank. It's a 78 550K. After I remove the petcock I find that the screen is flush with the tank which doesn't give much in the way of removing the screen. Looking for any tips or tricks short of ripping it to shreds getting it out and having to get a new one. Tank has been sitting for 30 years so there is some built up varnish hence the tank cleaning. I also wanted to see if using a cork to plug the petcock end would be sufficient when using acetone? I can't seem to find a small enough rubber stop.
http://www.westernhonda.com/fiche_section_detail.asp?section=2451813&category=Motorcycles&make=Honda&year=1978&fveh=131104
Number 3 in the fiche
http://s1168.photobucket.com/user/550Resto/media/tank2_zpsuafvcypr.jpg.html
Screen can be seen here
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Removing Fuel Screen
« Reply #1 on: March 30, 2016, 07:11:22 PM »
There's your answer.
Just replace it. I am buying a new screen for the 750 tank I'm redoing rather than trying to clean it... even though it's metal.
--Evan
1975 CB750K "Rhonda"
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: March 30, 2016, 07:29:26 PM »
You need a new screen. To remove the old screen I usually insert a sharp pick, awl, or even a finishing nail between the edge of the filter and the inside of the opening in the fuel tank. Once the edge of the filter can be grasped with needle nose pliers, twist and pull the old filter free. The new screen (from Honda) comes with a new petcock gasket too.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline flatlander
« Reply #3 on: March 31, 2016, 02:56:11 AM »
yes what the guys say... it's most likely going to be destroyed in the process. when you replace it make sure you get the correct one for your petcock and tank. be aware that the tank and petcock may not be matching the "year" of your bike so really check them carefully against the partslist (don't ask how i found out!).
Offline DaveBarbier
« Reply #4 on: March 31, 2016, 05:41:07 AM »
I've heard of people threading a bolt into the filter hole and pulling it out. I haven't tried that, might work. Worth a shot.
Your tank doesn't look that bad. And your filter seems to be in fine shape. I'd reuse it if you can pull it out.
If you do try that and it works, let me know! Maybe post a picture too. I've never seen anyone actually do that so it would be nice to know. :)
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: March 31, 2016, 05:41:55 PM »
Stick a long wooden dowel into the tank through the filler and push the screen out from the inside.
mystic_1
- John Augustus Shedd
Offline DaveBarbier
« Reply #6 on: March 31, 2016, 06:22:34 PM »
mystic_1
Don't think you'd be able to do that. Not enough leverage. Risks breaking the dowel and/or filter.
Offline 550Resto
« Reply #7 on: April 01, 2016, 08:37:07 PM »
Got it out with a small pick to get it loose from the sides of the bung then used needle nose pliers to get it out. Got one on order. How would one go about cleaning the pet cocktail of old varnish? I used acetone on the inside of the tank which cleaned the old varnish.
Offline evanphi
  • Apparently I'm an
« Reply #8 on: April 04, 2016, 08:06:41 AM »
Disassemble the petcock and remove (and plan to replace, for good measure) any rubber bits. Then a good soak in acetone.
--Evan
